KZ 1000 cylinder block max. bore size
25 Feb 2019 11:39
What is the maximum safe bored out size for a 77/78 KZ 1000 cylinder/sleeve?
Re: KZ 1000 cylinder block max. bore size
25 Feb 2019 12:07
1105
The following user(s) said Thank You: Scirocco
25 Feb 2019 12:29
So max. 73,00 mm bore size.
Thanks Steve
Thanks Steve
25 Feb 2019 12:48
I think it's the max for the liners. I plan on them for my bike.
- DFIGPZ
25 Feb 2019 13:48
Beware 1105 is Possible but Sleeves are thin 1075 a better option IMO.
1984 750 Turbo
The following user(s) said Thank You: Street Fighter LTD, Scirocco
- zed1015
25 Feb 2019 13:55
Max size on stock 1000 liners is 73mm = 1105cc.
It does leave the liners a little thin at the spigot which is prone to cracking at that size.
Also the thin liner also causes accelerated ring wear and oil consumption under high load as the liner suffers microscopic distortion.
Personally I don't go bigger than 72mm on the stock liner.
The following user(s) said Thank You: Nessism, Scirocco
25 Feb 2019 14:14
Ok thank you guys, then i will do an upgrade with this high compression piston kit with 70,50 mm bore size.
- gordone
25 Feb 2019 14:25
Looking foward to follow you upgrade project
I assume you update your project thread with pictures ad text?
Have consider replace liners so you can go bigger?
Project:
Project:
25 Feb 2019 14:45 - 25 Feb 2019 14:49
gordone, replacing the liners are much more expensive. do you have some extra 600 euro for me?
My engine case is bored for 1200 ccm liners, 80 mm OD
Last edit: 25 Feb 2019 14:49 by Scirocco.
25 Feb 2019 14:53
I have a spare 1015 block so I could go 1105 and keep the one I have as a spare.
25 Feb 2019 17:33
Hot combo
MTC 1075 cc kit in stock liners
- Big Jay
- Banned
25 Feb 2019 22:26
As one who has probably done more of these than anyone else, I can say the 1105 will fit and we do it for people who absolutely insist. However it is my opinion that a 1075 motor will make more power because the liners will stay round and provide ring seal. We still do a large number of 1075s. I believe the 70.5 mm kit the other poster is going to use would not be worth it when he could get an extra 50cc for the same money.
