Kz750-Gpz750 top end interchangeable?
Re: Kz750-Gpz750 top end interchangeable?
16 Feb 2019 16:25 - 16 Feb 2019 16:26
Our member Loudvx has a nice writeup about the tensioner issue here
s3.amazonaws.com/gpzweb/CamsKZZXZR550500...KZZXZR550500400.html
Last edit: 16 Feb 2019 16:26 by Nessism.
- KZB2 650
17 Feb 2019 05:33zukdave wrote: You'll see no gain without the GPz cams.
I'd have those cams in mine if it wasn't for the lobe center adj and losing the tack.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- Pipes66
17 Feb 2019 14:00
I’m not after gains,it’s a friends bike that I help out with,she doesn’t ride fast so I’m sure she’d prefer to keep the bike running the same. Makes a change hey!!
1983 kz750 F1 Ltd Shaft US model
- Pipes66
17 Feb 2019 14:03
I’m with you re the rubbing block in the cover, it’s actually a pita to adjust the manual one without removing the carbs.
- Pipes66
17 Feb 2019 14:21
The kz carbs will line up on the gpz inlets won’t they?
- baldy110
The following user(s) said Thank You: Pipes66
