Kz750-Gpz750 top end interchangeable?
- Pipes66
14 Feb 2019 02:46
As the subject asks,will a 83 ish gpz top end(pistons,barrels,head) go on a kz bottom end?
I’d love to swap the whole engine but the kz is shaft drive.
1983 kz750 F1 Ltd Shaft US model
Re: Kz750-Gpz750 top end interchangeable?
14 Feb 2019 04:37
There are a few differences that I know of. One, the early engines use a mechanical tach drive and the later bikes eliminated that and went to an electronic tach triggers off a coil signal or something like that. The shape of the fins on the later engines is different, and there was a change to the combustion chamber shape and pistons. If you have the entire top end to switch everything should swap over, but again, you will loose your tach.
- Pipes66
14 Feb 2019 05:45
I think my tach is electronic,there’s no drive off the cam,if that’s where it would be.
I was more concerned with bolt pattern and cam chain length/line up.
14 Feb 2019 17:12
Just noticed your signature line which states you have a shaft drive bike. Pretty sure everything will bolt up. When in doubt you can always check part numbers and do a comparison.
- baldy110
- Pipes66
15 Feb 2019 05:31
Wow,have I slipped into another dimension where things I want to work,work?:woohoo: :woohoo:
Is the gpz cam timing method the same as the kz?
- baldy110
15 Feb 2019 08:28
Yes, just be aware if your using the GPZ cams your gonna lose some low end torque. The hotter cams moves the power up the RPM range.
15 Feb 2019 14:28
Be sure to pull the cam chain tensioner wedge spring out before installing the valve cover, otherwise the chain will be over tensioner when the cover is installed.
- Pipes66
16 Feb 2019 04:08
I’ll use the kz cams then,thank you.
I’m using a manual cct at the moment,I assume you’re talking about the standard gpz one,I may use the standard one.
- zukdave
16 Feb 2019 09:32
You'll see no gain without the GPz cams.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
16 Feb 2019 13:24
[quote="Pipes66" post=798755}
I’m using a manual cct at the moment,I assume you’re talking about the standard gpz one,I may use the standard one.[/quote]
I didn't explain very well. Basically, there is a rub block in the valve cover which presses down on the chain. That's why it's important to do the chain tensioning after the cover is on, not before.
16 Feb 2019 13:59
I am total with Nessism statement.
I have seen a lot of cracked valve covers and broken cam chains after a cam install or valve clearance adjustment.
An automatic cam chain adjuster can be a PITA.
