KZ440 Won't Start After Top End Rebuild
- Jaytraeg
Re: KZ440 Won't Start After Top End Rebuild
10 Feb 2019 16:05
Shoot, I was actually really hoping something was wrong there.
The gap doesn't seem too large in person, probably only about a millimeter.
I DID remove the igniter. The repair manual says to remove the mounting bracket with the igniter and ignition coil before peeling the valve cover off. I just double checked the wiring harnesses (a 3-pin and a 2-pin), and they were both connected so the wire colors matched on both sides.
1981 KZ440 LTD
- loudhvx
11 Feb 2019 07:50
How fast does the motor seem to be turning over when you try to start it? The speed of the crank can affect the spark.
Also, if you remove both plugs and connect them back up to the wires, then lay them on the engine, can you raise one plug about 1/2" from the engine? That is, can you get a 1/2" spark out of it while cranking?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- OldguyJoe
11 Feb 2019 19:15
I hate to digress Jaytraeg, but per your concern about cooking the battery with excessive cranking:
consider jumpering to a car battery during your tests for increased endurance. Just be sure not to crank for more than 20 seconds at a time to avoid burning up the starter.
Again, after rebuild, I had to kick over for far longer than I thought reasonable before it fired.
1977 weird Canadian version of KZ400-s3
Had a 1973 Kawi 175 F3 trail bike in the 80s.
11 Feb 2019 20:25
If you jump the bike from a car battery make sure the car's engine is OFF. Otherwise you can damage the bike's electrical components. Ed
- Jaytraeg
14 Feb 2019 08:48
Thanks for all the advice folks, I really appreciate it. Great community here!
Loudhvx: The engine spins at a good speed when I try to start it. It turned over just as fast and with the same noises as when the bike would actually start, so nothing seems amiss there. I'll give the 1/2" spark test a go after I charge up the battery.
As for starting the bike from a car battery, I'm afraid I don't have access to a car at the moment. I'm away at college, so my resources are a little limited. I've been making sure to take it (relatively) easy on the starter, because I'd hate to have that break on me on top of whatever problems I already have with the bike.
One question I have is: what are ALL the things that could affect timing on the 440's? I'm convinced at this point that that must be it, because my spark is nice and juicy, I'm getting fuel and air, and have plenty of compression, while my sparking seems irregularly timed. I'd like to write out a list to completely check over to get my head straight on what it could be.
Thanks again for all the help, folks. I'm not giving up quite yet!
-Jean
-Jean
1981 KZ440 LTD
- Jaytraeg
22 Feb 2019 18:14
Well folks, it runs!
While waiting for the new igniter, I adjusted my valves (they were all pretty darn close to spec, but I wanted to make doubt sure), charged the battery, replaced the gasoline, and installed an on/off switch on my headlight to help save battery while cranking it. With a bit of starter fluid, it slowly began to cough to life.
However, it was running pretty rough when I got it started. There was a loud tapping coming from the bottom half of the engine on the right side, and giving the bike throttle would make it bog. After letting it run for a little bit, like a switch, it started running really well. It responded very well to throttle, the engine suddenly sounded different, and that tapping noise was gone in an instant. THEN, a little later (not having shut the engine off), it reverted back to poor running and made the tapping again, like a switch.
I checked the pipes, and both seemed to be getting warm at about the same rate. Thoughts?
Also, I can't thank you guys enough for the help. It takes a village, right?
1981 KZ440 LTD
- loudhvx
23 Feb 2019 12:32
That's great news that it at least runs. That suggests the igniter is probably ok.
Sounds to me it's running on one cylinder for a while, then the second cylinder fires up for a bit.
To rule out ignition, you want to figure out which cylinder is working and which isn't. Have you read about the water-spray test? That is the easiest, cheapest way, other than burning your fingers on the pipes (don't do that
Once you know for sure which cylinder is firing and which isn't, then you swap plug wires and try again. If the same cylinder does not fire, then the problem is the spark plug or fuel. (Assuming the engine is good, compression, valves, etc..) If the good cylinder goes dead, then the coil or plug wires should be replaced.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Jaytraeg
20 Mar 2019 20:39
Alrighty, well the bike started to run worse and worse, to the point that it wouldn't idle anymore. It would still pop like it was trying, but it just wouldn't fire. Starting fluid did make it start, but would die as soon as it ran out of starting fluid.
It seemed like no fuel was getting to the carbs, so I took them out and gave them a good soak in some Pinesol after reading about how long other people were doing that kind of soak, and went through the carbs with a thin wire to make sure every single passage was clear. It was while I had the carbs apart that I began to question if I had set the idle air mixture screw correctly the first time around, and after looking around a bit realized it was way off (I set it about 3 turns out instead of 1.5). I reset that and the darn thing started up no problem and ran like a champ... for a while. Then it started choking out again! Luckily, I installed a clear fuel filter inline on the fuel line, and I noticed I wasn't getting very good fuel flow when the petcock was set to on instead of prime or reserve, so I suppose my reserve on the gas tank starts really early (I still had about a gallon of gas in the tank). It runs great now, though! I took it out for a nice 20 minute ride the other day and it works like a champ.
I realize I'm rambling. TL;DR: The idle air mixture screws were set way wrong the first time I put it together, and I didn't have enough fuel to get adequate flow into the carbs. It runs!
Thank you SO MUCH to everyone with input in this thread, I was really banging my head up against the wall on this. If nothing else, the engine got a lot of fine tuning and preventative maintenance that could have been a pain later on. You guys are the best.
1981 KZ440 LTD
