KZ750 twin high lift spring kit
  • DoctoRot
  • DoctoRot's Avatar Topic Author
23 Jan 2019 12:34 - 23 Jan 2019 13:53
#797377
I'm trying to gauge interest here and see if anybody would be interested in a group buy. The stock KZ750 springs achieve coil bind at .450" lift so the max lift that would be safe is about .400". I sent a KZ750 twin head to Kibblewhite Precision Machining and they have scoped the head and have put together a higher lift spring kit using off the shelf parts, however it does require custom retainers and base washers. This kit would allow lift up to .475"
A complete spring kit would be about $160 to-$250 depending on interest.
in case you own a 750 twin and had not considered a cam Web Cams will do a custom regrind for about $350
Please let me know if you are interested, and if this is in the wrong section mods please feel free to move.
Last edit: 23 Jan 2019 13:53 by DoctoRot.
