Oil Cooler KZ 550
  • Madbear
  • Madbear's Avatar Topic Author
Oil Cooler KZ 550
16 Dec 2018 13:48
#795244
Please help
I have the KZ 550 engine first type. Without oil cooler outlet.
It is possible to connect the oil cooler to a plug and the motor plug.
It is possible to send a connection drawing.
Thanks for the anwers.
  • loudhvx
  • loudhvx's Avatar
Re: Oil Cooler KZ 550
16 Dec 2018 15:35
#795255
It would be much easier to get an oil pan that has the connections. But if you want to drill and tap for lines, I think it can be done. maybe this website will help:
s3.amazonaws.com/gpzweb/OilPans/Kz550oilPans.html
  • hardrockminer
  • hardrockminer's Avatar
16 Dec 2018 17:17 - 16 Dec 2018 17:18
#795262
There should be a pressure outlet on your oil pressure switch located on the back of the engine. There is a return port located on the right side, underneath your ignition cover.
Last edit: 16 Dec 2018 17:18 by hardrockminer.
  • Madbear
17 Dec 2018 03:17
#795271
I found the oil plan kz 650. Maybe is the oil pressure different than the kz 550? With the Kz 650 plug at the ignition, the oil pressure goes up to the head. At kz 550, oil returns here?
  • Wozza
  • Wozza's Avatar
17 Dec 2018 03:43
#795273
That plug you have written cooled oil returns here is correct
Thats the main oil gallery that feeds oil from the sump to the crank shaft bearings and then to the head.
While its possible to feed cooled oil into that plug its easier and cheaper to buy a sump from a latter model 550 that came with the oil cooler (all 550 gpz's and Zephyrs )
1982 KZ550H1
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
17 Dec 2018 04:08
#795274
These are from the Kawasaki GPz/KZ550 Factory Service Manuals. I second the using of a pan from an oil-cooled GPz550.
'85 GPz550(ZX550-A2)
  • Nessism
  • Nessism's Avatar
17 Dec 2018 04:40
#795275
I put a GPz cooler on my KZ750. Bought an oil pan with the take-offs, a GPz750 cooler with lines, and fabricated some frame mounts. An easy project all and all, completed for about $75 or so.
The following user(s) said Thank You: PtownSLUG
  • hardrockminer
17 Dec 2018 06:22
#795284
Apologies...I assumed that was a return port.
My KZ550 runs very cool so I am curious why you want to add an oil cooler?
  • Madbear
17 Dec 2018 07:28
#795293
Getting parts to GPZ or KZ is a big problem. All the motors in my country mostly ended up in the foundry :-)
And if I buy parts from Ebay, the postage price doubles the price of the part. It is better for me to make or remake things.
Thanks to all for your help.
  • Madbear
17 Dec 2018 07:36
#795294
I drive veteran racing tracks and the engine is overheated. I'm using the upper speed zone and the engine gets a good spin ;)
The following user(s) said Thank You: hardrockminer
  • Daftrusty
  • Daftrusty's Avatar
17 Dec 2018 09:27
#795301
The oil sump from a Zephyr zr550 will bolt right up to a kz550. It has the ports for the oil cooler and if you can find one, the zr550 oil cooler is much larger than the gpz550 one. The Zephyr was produced from 1990-1998 so it may be easier to find than the 1981-86 gpz's.
I have all the parts (gpz550 sump, lines and cooler) you need, but as you said, it would cost more to ship them than they are worth.
Hope this helps.
  • loudhvx
  • loudhvx's Avatar
17 Dec 2018 09:58
#795303
Did you get a chance to look at this link?
If so, can you identify which pan style you have?
The earliest type does not have a blank boss for cooler hookup.
If you have the 81 or later pan with the square cast boss, then I think you should be able to tap into that surface to get lines similar to the gpz pan. You will need to install a plug inside the larger port nearest that boss to divert the oil into the cooler otherwise it will just bypass your drilled ports. The boss might have enough meat on it to drill and tap pipe threads instead of using the o-ring-flange type hookup. (If I recall, Australia has different pipe threads than the U.S., not that that should be an issue.)
