Oil Cooler KZ 550
  • Madbear
  • Madbear's Avatar Topic Author
Re: Oil Cooler KZ 550
17 Dec 2018 11:17
#795309
I was looking at the link. Very nice web. I have the first version of the oil bath. This is unfortunately no output. I remove the oil pressure sensor and replace it with a hose connector. I do not use the pressure sensor anyway. Or I use the plug next to the oil filter that goes backwards. I'll see what's best for the exhaust.
  • loudhvx
  • loudhvx's Avatar
17 Dec 2018 12:40
#795312
Sorry, I meant to check one of my motors to see where a good place might be to tap into the main gallery, but I ran out of time. I'm at work now.
The pressure switch tap might work for a parallel-flow to the cooler, but it might be too small to run 100% flow. I'm not that well versed on oil coolers, but that pressure switch tap seems kinda small. If you run the cooler as a parallel-flow you might want to put a restrictor in the pan.
  • Wozza
  • Wozza's Avatar
17 Dec 2018 14:34 - 17 Dec 2018 15:41
#795319
DO NOT use the oil sensor port to feed the cooler and engine.
Look at the engine oil flow chart in coreys post , the switch is before the filter so It is unfiltered oil!!
The cooler needs to be in between the oil pan passage and the main passage (4-5)
1982 KZ550H1
Last edit: 17 Dec 2018 15:41 by Wozza.
  • Wozza
  • Wozza's Avatar
17 Dec 2018 16:13 - 17 Dec 2018 17:16
#795328
what you would need to do if you don't want to buy the oil cooler pan or drill and tap holes to fit oil lines.
Connect oil cooler feed line to rear 3/8bspt plug hole
Connect oil line from cooler to main oil passage below ignition cover. I am pretty sure its a metric thread.
Plug old oil passage in pan otherwise oil will bypass cooler
IF i couldn't get hold of a oil cooler pan then i would look at copying the factory pan and drill and tap the front of the pan for the new lines
1982 KZ550H1
Last edit: 17 Dec 2018 17:16 by Wozza.
  • Irish Yobbo
  • Irish Yobbo's Avatar
17 Dec 2018 16:14
#795329
I'm not 100% but just a thought - will you need a different/higher pressure oil pump? The only reason I ask is that I know that the GPZ750 has a different oil pump to the KZ750, and the only difference I could reason is that the oil cooler might effect oil pressure.
1981 KZ750 LTD
  • Wozza
  • Wozza's Avatar
17 Dec 2018 16:20
#795331
Irish Yobbo wrote: I'm not 100% but just a thought - will you need a different/higher pressure oil pump? The only reason I ask is that I know that the GPZ750 has a different oil pump to the KZ750, and the only difference I could reason is that the oil cooler might effect oil pressure.
All 550's with or without the oil cooler used the same pump
1982 KZ550H1
  • Daftrusty
  • Daftrusty's Avatar
17 Dec 2018 19:55 - 17 Dec 2018 19:56
#795341
Fun fact...all the gpz/kz550, kz650, kz700, gpz/kz750, zephyr 550/750, zx600a-c ninja and many more all used the exact same oil pump.
Part # 16082-064
The zr-7 was the one that got the higher volume oil pump.
Last edit: 17 Dec 2018 19:56 by Daftrusty.
  • Madbear
18 Dec 2018 03:45
#795346
Thanks for the super layouts of Master Wozza!
I will try to connect to 3/8 and the ignition plug has M18x1.5.
I have a M12x1 connection on the radiator. The inside diameter of the hose is 8mm. I can put a small pressure gauge in the circuit for inspection.
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
18 Dec 2018 10:50
#795366
Madbear wrote: Getting parts to GPZ or KZ is a big problem. All the motors in my country mostly ended up in the foundry :-)
And if I buy parts from Ebay, the postage price doubles the price of the part. It is better for me to make or remake things.
Thanks to all for your help.
Where do you live?
'85 GPz550(ZX550-A2)
  • Madbear
18 Dec 2018 11:28
#795367
Czech Republic
Small country with great possibilities :)
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
18 Dec 2018 12:18 - 18 Dec 2018 13:02
#795369
Last edit: 18 Dec 2018 13:02 by Scirocco. Reason: Add pics and links
  • Madbear
18 Dec 2018 13:35 - 18 Dec 2018 13:42
#795373
It's nice you want to show me how stupid I am.
1. I do not register on Ebay.
2. Shipping exceeds the price of parts (I already wrote)
3. The seller must be willing to send to my country.
4. I do not have Paypal :-)
5. I have to bother friends to mediate it.
6. I like to do things myself! Everyone can buy it!
I've already bought a few parts on an ad with photos.
And then I joyfully threw them into scrap.
Last edit: 18 Dec 2018 13:42 by Madbear.
