small oil leak at cyl head
- gordone
Re: small oil leak at cyl head
30 Nov 2018 06:58CCrosswait wrote: Had a similar issue on my KZ1100 after I first brought it home. Turned out the problem was the o-rings between the top of the cylinder and bottom of the head. On the 1100 they seal around the outside studs for oil return.
Looks like the 550 has a different arrangement but still uses some type of o-ring, part number 92055-1147. Might be worth investigating.
I had the same, I understand the reason is the o-ring get old and hard. I got a tips try to torque the top bolt just alittelbit exstra?
Project:
Project:
- Sfgpz550
01 Dec 2018 10:29
Gordone,
Could you tell me more details about how you torqued the top bolt? I'm a little nervous about the idea of torquing it extra. How far over the spec did you go, and did you only torque the two bolts on that side of the head, or did you tighten all 12 of them equally? Also, did you loosen them a little before torquing?
thanks
thanks
01 Dec 2018 10:40
I'd be leary torquing old gaskets and O rings.
- gordone
01 Dec 2018 12:53
I dident neeed todo it since I rebuilded the engine.
I will see if I can find the thread about it.
If youconfigure your torque wrench to nm speck, and yourfinger the nuts is below spack today you cannot do any harm or?
Project:
Project:
