small oil leak at cyl head
- Sfgpz550
25 Nov 2018 09:08 - 25 Nov 2018 09:20
I have a small amount of oil seepage on the left side of the engine at the gasket for the cylinder head. Is it OK to leave as is, or should I try to torque the bolts (as one post suggested).
Last edit: 25 Nov 2018 09:20 by Sfgpz550.
Re: small oil leak at cyl head
25 Nov 2018 11:10 - 25 Nov 2018 15:36
Is the leak at the valve cover or is it at the cylinder head Base gasket?
Last edit: 25 Nov 2018 15:36 by martin_csr.
25 Nov 2018 12:31
It certainly would do no harm to insure that the head nuts are torqued to spec. Do not over-tighten them.
- Sfgpz550
25 Nov 2018 13:01
the leak is not at the valve cover. It is on the left side between the cooling fins where the base gasket is. It is doesn't appear to be much oil at all, just visibly moist. There is not a leak in the same position on the other side.
what would be the correct procedure for torquing the head nuts to spec? Do you have the torque spec for those?
thanks
thanks
- slmjim+Z1BEBE
25 Nov 2018 16:07
What bike?
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Sfgpz550
25 Nov 2018 18:29
gpz550.
I checked the torque on the cyl head nuts, and they all seemed tight enough (according to spec in the manual i found online: 16.5 ft-lbs for the 12 cyl head bolts).
26 Nov 2018 05:27
Here is a PDF copy of the factory manual you can download for free. It covers 1979-1983.
www.kzrider.com/service-manuals
- JR
26 Nov 2018 05:41 - 26 Nov 2018 09:42It is on the left side between the cooling fins where the base gasket is.
I have a "visibly moist" area at the base gasket behind cylinders 3 and 4.
The base gasket is at the base of the cylinders between the cylinders and the engine cases or gearbox.
Is this where your leak is?
I can poke a bit of kleenex or paper towel in ther once a week and see it come out oil stained. Never enough oil to drip. It has been like that since i bought the bike 15 years ago. Bike runs fine, compression is good - not that I would expect a small base gasket leak to effect compression. For me its not worth the trouble of tearing it down to fix. And will wait until or if i need to do a major overhaul
Last edit: 26 Nov 2018 09:42 by JR.
- Sfgpz550
27 Nov 2018 18:43 - 27 Nov 2018 18:44
JR, I'm sorry for not explaining clearly. Another person had written "valve cover or cylinder head base gasket," and I think that my use of "base" confused matters. the leak is not at the base of the engine block, it is on the side of the engine between the engine block and the cylinder head. If you were to remove the cylinder head, there would be a gasket there, and this is where the small amount of oil moisture is appearing--viewed from the left side of the bike.
I have had the bike about a year and have noticed it and never thought much of it, but now I'm just wondering if it is something to address. I have never checked compression, but the bike pulls strong. Is a leak at the gasket between block and cyl head more concerning than base gasket? Removing the cyl head appears to be more of a job than I'm up for, based on what I've read in the manual.
Last edit: 27 Nov 2018 18:44 by Sfgpz550.
27 Nov 2018 20:48
Is it on the left side? There is always an oil buildup on the left side of the engine when the engine is left on the side stand. Try leaving the bike on the center stand and watch for the oil leak. If it disappears then it's just due to the oil buildup on the left side when the bike is leaning that way. If it still weeps even when the bike is left on the center stand then you can either live with it or pull the head and change the gaskets.
- Sfgpz550
29 Nov 2018 17:41
Yes, it is on the left side. However, the bike didn't come with a center stand--the PO removed that. I didn't realize that there could be a noticeable leak from parking on the side stand, but that's good to know. I think I'll to not worry about it for the time being.
- CCrosswait
29 Nov 2018 19:50
Had a similar issue on my KZ1100 after I first brought it home. Turned out the problem was the o-rings between the top of the cylinder and bottom of the head. On the 1100 they seal around the outside studs for oil return.
Looks like the 550 has a different arrangement but still uses some type of o-ring, part number 92055-1147. Might be worth investigating.
2019 Indian FTR1200S
2018 Triumph Rocket 3
1981 Kawasaki KZ1100A1
1977 Yamaha RD400
1980 Honda Express II
1977 Yamaha RD400
