Exhaust Pipe Cold - KZ650 - and rattling.
- bluej58
Re: Exhaust Pipe Cold - KZ650 - and rattling.
14 Oct 2018 06:13
If it is only 1 pipe that is cold on start up but warms up when actually riding, I would suspect a clogged pilot circuit.
If it never warms up I would think in has to do with wiring.
78 KZ1000 A2A
- 650Dude
- Banned
16 Oct 2018 09:54bluej58 wrote: Which pipes are not getting hot?
The rattling noise may be from a loose or bad exhaust ring, when the bike is cold grab the exhaust pipes up by the head and try to move them sideways , if you find any movement try to tighten down the flange , if that dosn't help replace the rings
Well I changed the spark plugs today.
When I took out the old one cylinder #10) there was oil on it, but not the others.
Started up that bike and smoke came out of the left hand exhaust (bike still has the original exhaust). When I roll the throttle even MORE smoke comes out.
So what might this be?
1977 Kawasaki KZ650B
1977 Kawasaki KZ750 Twin
16 Oct 2018 14:37
Valve guide seals.
16 Oct 2018 15:10
1+ Steve, as i reply in 650Dude other post, renew the valve stem seals first.
www.kzrider.com/forum/2-engine/609433-19...uild-hope-not#792394
- 650Dude
- Banned
16 Oct 2018 16:38SWest wrote: Valve guide seals.
Im indebted to you guys. thanks so much!
- 650Dude
- Banned
16 Oct 2018 16:38Scirocco wrote: 1+ Steve, as i reply in 650Dude other post, renew the valve stem seals first.
Many thanks to you as well.
