No Valve Clearance
  • KZ1000P1995
  • KZ1000P1995's Avatar Topic Author
No Valve Clearance
01 Sep 2018 00:25
#790084
Hey All,
You have all been a tremendous help for me over the last couple of years and I have greatly enjoyed riding my KZ1000P all over the Olympic Peninsula. Well, tonight I had some spar time and thought I would check the valves due to hearing what sounded like valve tapping.
I was shocked to discover that all but 2 valves had no clearance of any kind are are most likely touching the shims. What gives!? When I checked last year I had 0.10-0.15 mm on all valves. I had expected, if anything, larger clearances due to normal wear and breakin, not the exact opposite. I don't even know how to judge what size shims I will need to order now. Please help with your thoughts on what happened and what I should do next, thanks.
  • Nessism
  • Nessism's Avatar
Re: No Valve Clearance
01 Sep 2018 05:14 - 01 Sep 2018 05:15
#790091
The clearance reduces with mileage because the valves recede and sink into the head. You need a thin "checking shim" that can be installed into each bucket so the true clearance can be calculated. Another option is to order a bunch of shims smaller than what you have installed now. I'd plan on moving two shim sizes on the valves with no clearance.
Last edit: 01 Sep 2018 05:15 by Nessism.
  • KZ1000P1995
01 Sep 2018 09:28
#790102
Hi Ed,
I only question why they wore so much in the 800 miles I put on the bike since I lapped the valves and shimmed them to .10 - .15 clearance. I even checked them after riding for about 300 miles after the rebuild and they were all well within spec. Now, 500+ miles later they are almost all touching the shims. Thanks!
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Sep 2018 11:28
#790107
I had two do that after my tipping job. I'd go down two sizes. You will wind up with some you can use later.
kzrider.com/forum/2-engine/605981-valve-adjustment-z1-kz-1000
  • Nessism
  • Nessism's Avatar
01 Sep 2018 12:27
#790112
KZ1000P1995 wrote: Hi Ed,
Sorry, don't know the answer. Hopefully you are running stock valve springs, not high strength jobbies from APE or similar. That will make the valves recede faster.
  • KZ1000P1995
01 Sep 2018 18:19
#790122
Thanks fellas, appreciate the videos SWest.
