Replacing cylinder head studs to APE studs
  • SWest
  • Topic Author
  • 10 22 2014
15 Jun 2018 07:10 #785197 by SWest
I did a search but no tips on just taking out the stock studs. I have a plan for this and will be taking the head off only and replacing them with HD APE studs. Will probably be doing this tomorrow after soaking them with the acetone/tranny fluid concoction. Heat up the case around the stud base and try to screw them out. Any suggestions?
  • Street Fighter LTD
  • Moderator
15 Jun 2018 09:38 #785204 by Street Fighter LTD
Replied by Street Fighter LTD on topic Replacing cylinder head studs to APE studs
You can double nut them and give it a try. ( Usually works )
Or I purchased the APE stud puller tool from Jay. Always works , but buggers up the old studs.
Next thing Steve is new HD APE Nuts .. I got a lot of years out of the Kaw OEM nuts but when they wore out I went HD APE
Good Luck
15 Jun 2018 12:23 #785208 by MDZ1rider
Replied by MDZ1rider on topic Replacing cylinder head studs to APE studs
I don't know if you have them on the west coast, but back east we have an auto parts chain called Advanced Auto. They have a free tool loaner program. You pay a deposit for the full tool price and get it a full refund when you bring the tool back. They had a Metric stud puller set for loan. I think the set was less than $30, so I just bought mine. If you need a tool once, there's a good chance you're going to need it again. Dave is right. it still bungs up the threads a little on the stud you are removing.
15 Jun 2018 12:59 - 15 Jun 2018 13:00 #785212 by Nessism
Replied by Nessism on topic Replacing cylinder head studs to APE studs
I used a stud puller from Harbor Freight. It worked fine but left marks on the studs. Double nutting thrashes the threads so I'd rather mark up the shank than the threads...but I suppose if you are throwing away the studs it won't matter.
EDIT: can't find the Harbor Freight tool but it looks just like this one... www.amazon.com/Lisle-71200-Stud-Remover/dp/B0041ESF2G
Last edit: 15 Jun 2018 13:00 by Nessism.
  • SWest
  • Topic Author
  • 10 22 2014
15 Jun 2018 15:04 #785216 by SWest
Replied by SWest on topic Replacing cylinder head studs to APE studs
The only time I had to remove cylinder head studs was on my 350 Honda. They were a bear. I thought it would be easier than pulling the engine. I guess it was but not by much. :dry: If I have trouble I can go to OR or AZ but the concern I have is snapping one being it will be so far up. :unsure:
  • z1kzonly
15 Jun 2018 18:06 #785231 by z1kzonly
Replied by z1kzonly on topic Replacing cylinder head studs to APE studs
Yes Steve, you will get a good 1/8 to 1/4 flex, turn with vise grips up that high. So be sure your going to do this! I would get a nice new set of good vise grips with nice sharp teeth on the jaws! get it as tight as you can squeeze it! Right on the bottom of the thread area. Maybe tighten a stud nut down to it also. I like the propane torch heat too.
Then go for it!
Worst case scenario is, you would have to pull the block off the pistons
  • Moderator
15 Jun 2018 18:17 #785232 by Street Fighter LTD
Over the years I have busted 2 studs off flush with the case.
It pays to know a first class machinist.
First one back in the early 80s we jigged up and drilled it out.
Had one snap on last rebuild and also had a busted off bolt in left side of cases.
Lucky for me my very good friend sells EDM machines and had a shop remove the offending bolts/ studs
Dave.
  • SWest
  • Topic Author
  • 10 22 2014
15 Jun 2018 19:01 #785235 by SWest
16 Jun 2018 10:11 #785257 by wiredgeorge
Replied by wiredgeorge on topic Replacing cylinder head studs to APE studs
I have a pro quality metric stud removal tool set. Problem is, it grabs the stud and that makes it easier to break the stud off if you are ham handed. Guess you can break them off with about any tool. I have broken them off and while I have a drill press, it isn't big enough for a case half. Drilling the old broken stud is an exercise in futility and i would drag the case to a machine shop if it happened again. And last, they don't seem to snap in the middle of the stud but snap off at the base.
  • SWest
  • Topic Author
  • 10 22 2014
16 Jun 2018 10:14 #785259 by SWest
That's what I'm afraid of. If they don't come out easy I'll move on.
  • SWest
  • Topic Author
  • 10 22 2014
17 Jun 2018 17:13 #785346 by SWest
Could have been a F@!$ed up day with just one SNAP but got it done. B)
22 Jun 2018 23:16 #785694 by Big Jay
Replied by Big Jay on topic Replacing cylinder head studs to APE studs
APE has a neat little stud install tool that does not damage the threads.
