Valve adjustment methods
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
07 Jun 2018 16:08
#784755
I'm starting this thread to start a discussion. Thoughts?
  • Nessism
  • Nessism's Avatar
Re: Valve adjustment methods
07 Jun 2018 18:40
#784758
Valves adjusted in adjacent pairs is best. This is because both side by side valves are on the base circle. When the adjacent valve is compressed and pushing up on the camshaft it skews the cam in the journal clearance which falsely increases valve clearance by as much as .002"
The later bkg KZ manuals call for this method. Not sure about the early manual. Suzuki GS bikes are adjusted this way too and the shim and bucket GS's are LONG lasting engines (if the owner adjusts the valves anyway).
  • VTEC
  • VTEC's Avatar
08 Jun 2018 08:54
#784785
Yep. Just discussed this. I get .001" less clearance doing side-by-side valves as per the manual as compared to exhaust and intake @ TDC, or each lobe straight up from the bucket. This seems to be the position of least clearance, and therefore the best method.
KZ1000-K2
ZRX1100
XR400R
