Intake Boots - Fuel
  • cg94
  • cg94's Avatar Topic Author
Intake Boots - Fuel
06 Jun 2018 12:46
#784720
Just got back from a ride on my 78 Kz650 SR. I noticed recently when I did a carb sync with vacuum gauges that a couple of the intake boot nipples had gas in the caps when I took them off to attach the hoses. Is this normal or am I running too rich of a mixture? Based on looking at the plugs the color seems to be good. Although I'm still struggling to know if my air mixture screws are at the right point ( I have them all set to around 2 turns out and they seem to be at their strongest idles ). Any tips would be appreciated, thanks!
1978 KZ 650 SR
Re: Intake Boots - Fuel
06 Jun 2018 13:04
#784721
Gas in the nipple caps is normal. Ed
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
06 Jun 2018 13:10
#784722
Some drops of fuel in the rubber caps is normal, no reason to worry about it.
Some people switch the intake boot vacuum nipples on to the top.
