Engine oil
  • Ojisan rider
  • Topic Author
23 May 2018 21:33 #783915 by Ojisan rider
Engine oil was created by Ojisan rider
Now, I know I'm gonna create some chaos if I ask what will be the best oil to use, , so I'm just gonna ask what oil you guys are using.
It's been a while since I rode a bike, and because my ZX rebuild is taking bit more time than I expected, I started on my KZ rebuild recently. No. I have not started the build-up yet as the frame/tank/side and tail need to go to paint shop. But in the mean time, I started to collect parts I need, both for the chassis and engine. And whenever possible, I test fit the part(s) I got to the engine, so I want to start buying some engine oil.
Yes. I do use engine assembly lube (both tube and liquid type depending on where). Yes. I took the engine apart and it's in pieces. I just wanted to make sure it wasn't rusted inside. Most are OK. I needed to get some parts like bearing as it showed some sign of rust.
I guess my main concern will be for the clutch.
When I was riding this bike, choices were pretty limited. Now with so many products, I have no idea what to use. Any help will be appreciated!
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
24 May 2018 05:49 #783923 by TexasKZ
Replied by TexasKZ on topic Engine oil
Most importantly, it should be JASO-MA compliant and be within the viscosity range specified by Kawasaki.
  • ThatGPzGuy
24 May 2018 06:28 #783926 by ThatGPzGuy
Replied by ThatGPzGuy on topic Engine oil
I've been using Rotella T4 in all my MCs with no issues. Cheap too, by the gallon.
www.amazon.com/Shell-ROTELLA-Triple-Prot...rmerly/dp/B01LH7L0XA
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: Nessism, Street Fighter LTD, SWest
24 May 2018 07:14 #783932 by Nessism
Replied by Nessism on topic Engine oil
I use diesel engine oil. Such oils have lots of good additives appropriate for our bikes. Rotella is excellent but I don't limit myself to that and MA certification isn't necessary in my view although Rotella is certified. Diesel engines don't use wet clutches so most makers of diesel oil don't bother to go through the MA certification testing because that drives cost. Shell made a business decision to spend the money though and for that they get the nod from motorcycle guys that like the warm and fuzzy feeling that the certification brings. I've used various diesel oils over the years and have yet to experience any negative behavior from my bikes, including the clutch.
24 May 2018 08:08 #783938 by martin_csr
Replied by martin_csr on topic Engine oil
Kind of reiterating what Nessism said. I use either Shell Rotella T 15W-40 regular in the white bottle or Chevron Delo. Both are marketed as heavy duty diesel engine oils & they usually go on sale for around $13 gal. Valvoline Premium Blue is a similar heavy duty oil, but it's more expensive. The Shell Rotella has the JASO-MA rating, somewhat recently attained by getting the certification, but they didn't have to change their oil to get the Japanese rating.
  • slmjim+Z1BEBE
24 May 2018 11:52 - 24 May 2018 11:54 #783952 by slmjim+Z1BEBE
Replied by slmjim+Z1BEBE on topic Engine oil
Kawi 20w - 50 mineral in the Z1's.
Mobil1 15w - 50 full syn in the Nighthawks.
Rotella T6 full syn in the ST1300.
Now, where did that popcorn emoji go...?
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Last edit: 24 May 2018 11:54 by slmjim+Z1BEBE.
24 May 2018 12:12 #783954 by KZB2 650
Replied by KZB2 650 on topic Engine oil
Been using 10/40 Valvoline bike oil as I ride in 65 to 85 degree weather and like the quicker flow when cold. Lately been adding a half a quart of there 20/50 to the mix. Wish they'd come out with a 5/45 oil...... bike starts almost instantly and would like to make sure it flows to all areas fast.:silly:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
24 May 2018 16:30 #783970 by VTEC
Replied by VTEC on topic Engine oil
I'm going Valvoline motorcycle 4-stroke 10w40 for the first few thousand miles (break-in). Then going to Mobile 1 Racing 4T 10w40 after that. Definitely not the cheap stuff, but supposedly the best. I don't like to mess with OEM weights. Back then street viscosity was to help engines, now thinner weights do more for the MPG . Racing is another story.
KZ1000-K2
ZRX1100
XR400R
  • Ojisan rider
  • Topic Author
24 May 2018 20:13 #783976 by Ojisan rider
Replied by Ojisan rider on topic Engine oil
Thanks for all the input guys.
Because of where I live, I have to go out and start looking for all the oils you guys mentioned and see if it's available here. Most of the time, the stuff you guys mentioned won't be available here. Supply and demand, I suppose. Case in point. Shell Rotella or Delo oils. I know I can get the dino oil, but never seen the synthetic ones, yet. And because of HAZMAT, I can't get it to ship here. If I'm lucky enough to find what you guys mentioned, I probably have to sell my Kidney to get it.
Anyway, I'll keep you guys posted. And once again, thanks for all your input.
24 May 2018 20:20 #783977 by Nessism
25 May 2018 06:13 - 25 May 2018 06:23 #783982 by martin_csr
By Ojisan rider : ...
Shell Rotella T 15-40 is a regular oil, not synthetic, and the Chevron Delo 15W-40 I use mentioned above is also a regular oil.
Shell Rotella T4 is a regular oil & it's the "improved" version of Rotella T, but I did not see ZDDP listed in an MSDS.
Rotella T6 is synthetic, and Rotella T5 is a synthetic blend oil (regular oil + synthetic oil mixed together).
You can probably use any heavy duty oil marketed for diesel engines, since they usually have the anti-wear additive ZDDP which is the same compound found in motorcycle oils. Most MSDS product sheets will indicate the amount of ZDDP, usually around 1-2%, but sometimes indicated as PPM.
One thing to consider is your climate: If it's cold, the 15W-40 may not be good for cold starts.
Last edit: 25 May 2018 06:23 by martin_csr.
  • Ojisan rider
  • Topic Author
25 May 2018 23:40 #784048 by Ojisan rider
Luck had me going to local Walmart today. Just as I said, no synthetic ones. Found T4 and T5, but no T6.
Anyway, still searching for other oil as well.
Wish me luck!
