Cam chain broke. Where do I go from here?
  • Kaz
  • Kaz's Avatar Topic Author
21 May 2018 14:41 - 21 May 2018 14:42
#783794
I have an kz750 twin. It wasn’t turning over so I took off the valve cover. There was no tension in the chain, I pulled on it and the chain came off and showed a broken link. Looks like I have a lot of work ahead.
I was considering putting a new chain on it but that seems like quite a bit of work. Before I get too deep into this project I wanted to ask if there is a guide / checklist for other areas to look while I have the engine out of the bike.
I also don’t want to spend thousands of dollars to find out I skipped a step and I have a paperweight.
Ive been searching online and there are not many resources for the twin.
Any help would be appreciated
Last edit: 21 May 2018 14:42 by Kaz. Reason: Attachment didn’t attach
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Cam chain broke. Where do I go from here?
21 May 2018 14:51
#783795
Sorry to hear of your misfortune.
No cost to tear it down and check motor over as long as you have a factory service manual.
Follow the steps. Keep all parts organized.
Check each over for damage.
Post lots of pictures for us to help.
Then make a shopping list of what needs to be done.
  • Nessism
  • Nessism's Avatar
21 May 2018 14:53
#783796
What is the history of the bike? Did you just buy it? If so the broken chain may have occured while riding and now there is carnage inside the engine including bent valves among other things. I think you are looking at a full engine teardown to fix the bike right.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
21 May 2018 15:49 - 21 May 2018 15:51
#783801
Sorry to hear of your worst case scenario.
You have to pull the head first to check for bend valves. Later you have to split the engine case to renew the cam chain. Take of the oil pan first for cleaning and removing the broken cam chain parts.
Long story short, you have to remove the engine out of the frame for a better access to all parts.
A service manual is necessary for a beginner and engine a rebuild.
We will guide you to the rebuild process.
kzrider.com/modules/ServiceManuals/Kawas...l%20KZ750%20Twin.pdf
Last edit: 21 May 2018 15:51 by Scirocco.
  • Kaz
21 May 2018 16:40 - 21 May 2018 16:42
#783804
He bike wasnt running when I bought it. I thought it would be a carb issue. Once i got those off i saw the valves werent moving and now Im in my current predicament.
While i have the head and case off, are their gaskets or other parts that should be replaced. I would hate to do the work and skip a component
Last edit: 21 May 2018 16:42 by Kaz.
  • Nessism
  • Nessism's Avatar
21 May 2018 17:16
#783805
You can see all the various parts, including gaskets and seals, by looking at the parts fishe... www.partzilla.com/
I strongly advise toward OEM gaskets and seals where ever possible. Sometimes you can find good deals on OEM parts via ebay so you may want to check ebay once you find the part numbers you need. You should also get a real Kawasaki service manual. Not a clymers or Haynes. Money well spent.
  • Z1Driver
  • Z1Driver's Avatar
  • love the smell of triple smoke
21 May 2018 17:42 - 21 May 2018 17:42
#783807
Might check You Tube. Sometimes there are good vids on how to do something before going into it.
Blue 1975 Z1B
Red 2009 Concours 14
Last edit: 21 May 2018 17:42 by Z1Driver.
  • loudhvx
  • loudhvx's Avatar
21 May 2018 20:01
#783818
Maybe post your general location so we can keep a lookout for any possible used 750 twin motors available. They are not very common, but do come up once in awhile.
  • SWest
  • SWest's Avatar
  • 10 22 2014
21 May 2018 20:40
#783819
Well you can look at it this way, once you've gone through it, you'll have that certain satisfaction in knowing what's happening in between your legs. B)
THEN YOU CAN RIDE THE PISS OUT OF IT. :woohoo:
  • Kaz
22 May 2018 12:18 - 22 May 2018 12:23
#783841
I’m in the Seattle area.
Is there a recommendation for an engine stand?
I watched an old school Kawasaki repair video-
Am I going to need to remove the transmission/ clutch to get to the crank?
I found the part number on partzilla, 92057, and checked eBay for the same part number. I found a few auctions selling that part number but it was listed for other models:
rover.ebay.com/rover/0/0/0?mpre=https%3A...2Fitm%2F132242337451
www.partzilla.com/catalog/kawasaki/motor...afts-chain-tensioner
Any thoughts on that eBay auction
Last edit: 22 May 2018 12:23 by Kaz.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
22 May 2018 14:11
#783843
First download and read the manual before you buy any parts.
Pull the engine out of the frame, made a list of tools you need to do a engine overhaul.
Remove and disassemble the head and look for bent valves and/or piston dome damages.
Do small steps and post your progress and findings with some pics.
If the replacement parts list goes to long a replacement engine would be cheaper!!!!
  • loudhvx
  • loudhvx's Avatar
22 May 2018 19:21
#783851
Too bad this one is not closer to you. I think it's a twin. If it's a '77 it must be.
So they are out there.
milwaukee.craigslist.org/mcy/d/rare-barn...cles/6565802917.html
