Time serts for cam cap thread repair
  • barney
  • barney's Avatar Topic Author
23 Apr 2018 12:42
#782243
Ok so i purchased time serts to repair 6 damaged exhaust cam cap retaining threads. It appears that the inserts are not designed for a fastener to be threaded all the way through. Looks like they aren't completely threaded all the way through . I wasnt aware of this . I ordered the 9.4 mm long inserts and the longest thats available is 14 mm long. Any ideas from anyone who has used these things?
Thanks
Barney
  • Nessism
  • Nessism's Avatar
Re: Time serts for cam cap thread repair
23 Apr 2018 15:22
#782247
Not an expert, but I thought Time-serts had a few threads on the bottom of the insert that are not fully formed, then during install you run the "expander" through the insert and it pressed it into the wall of the hole and finish formed those threads. I know that spark plug repair Time-serts thread all the way through anyway.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
23 Apr 2018 17:06
#782252
I think what you want are these: www.mcmaster.com/#threaded-inserts/=1cjl9hv
It's what I use anyway... You'll need a blind tap and the tool to screw them down.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Nessism
  • Nessism's Avatar
23 Apr 2018 17:12
#782254
Helicoil's work fine for that application too. Key thing with cam caps is to use vice grips and press the cam down into the head before installing the cams, that way the threads are no stressed so much.
  • 78z1Joe
  • 78z1Joe's Avatar
  • My man cave is my garage....
23 Apr 2018 18:59
#782261
Hi, ok what do you suggest for a stripped valve cover bolt hole? And proper installation tools and technique? Thanks!
1978 KZ 1000
1982 GS 300 training bike
Previous Rides...
75 RD 350
72 CB 500 Four
72 SL 125
71 CT 70
69 3 1/2 HP mini bike
  • zed1015
  • zed1015's Avatar
24 Apr 2018 00:13
#782269
78z1Joe wrote: Hi, ok what do you suggest for a stripped valve cover bolt hole? And proper installation tools and technique? Thanks!
There's no problem using Helicoil style wire inserts almost anywhere on the engine as long as they are fitted correctly.
Kits are very cheap and come with tools and instructions.
Once the hole has been drilled and tapped square and true the trick is to keep constant pressure on the coil when installing it so that it doesn't skip a thread which would cause the bolt to jam when screwed in.
Also make sure the top of the helicoil is at least one thread below the surface .
At the end of the day it's all down to the competence of the person doing the work.
  • Kawboy74
  • Kawboy74's Avatar
30 Apr 2018 17:46
#782667
Hi Paul
I have never seen anything like that not threaded all the way through. I was told by a machinist that you buy an insert 3/4 the length of the width of the bolt you are using and it should be plenty,the rest passes through the insert. So a 6mm bolt would use a 9mm insert. I have always used Helicoil or similar products that come with the drill, insert wrench and an assortment of coils. Give me a call if you like.
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • Kawboy74
  • Kawboy74's Avatar
30 Apr 2018 17:47
#782668
Sorry, bad math day, 1.5 times the width.
