Cant get my oil filter cover off ('81 KZ650 CSR)
  • Cata2k
  • Cata2k's Avatar Topic Author
22 Apr 2018 13:46 - 22 Apr 2018 13:53
#782179
Hey, I'm doing my first oil change on my first bike but the filter cover wont come off? Which way do I turn the screw? Assuming I'm laying down looking up. I know, I know, lefty loosy, yadda yadda yadda, but it doesn't budge. Am I a moron and its reverse threaded? Is it just stuck?
Last edit: 22 Apr 2018 13:53 by Cata2k.
  • scubaanders
  • scubaanders's Avatar
Re: Cant get my oil filter cover off ('81 KZ650 CSR)
22 Apr 2018 14:21
#782180
You turn the bolt for the cover anti clock wise.
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Apr 2018 14:57
#782182
Be sure to use a tight six point socket on it. R/H thread. They will be tight after a while. If you need to lay it on it's side to get a better bite or use this do it.
  • Nessism
  • Nessism's Avatar
22 Apr 2018 15:46
#782185
scubaanders wrote: You turn the bolt for the cover anti clock wise.
Correct. An alternate perspective...if you are sitting alongside the engine and turning the wrench looking down from the top you need to turn clockwise.
  • KZB2 650
  • KZB2 650's Avatar
22 Apr 2018 16:48 - 22 Apr 2018 16:49
#782187
There you go Nessism........ can't remember the torgue specs off hand but I find them to be a good 20 to 25% too tight for me. Done them a hundred times over the years by hand and after finally checking with a wrench I was closer to the looser specs never with a problem.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 22 Apr 2018 16:49 by KZB2 650.
