Exhaust Cam tach drive damage
- cg94
20 Apr 2018 06:04
I was torquing my exhaust cam down and had forgotten to remove the tach worm gear from the bike. It’s a 1978 kz650 SR. The damage is fairly minimal. Will I need to replace the exhaust cam or will the worm gear and cam work together since the damage is minimal? Thanks!
1978 KZ 650 SR
Re: Exhaust Cam tach drive damage
20 Apr 2018 06:43
You could clean that up with a file but if the tach drive is bent it needs to be replaced.
