recommendation for carbs on new motor
- marcumc
16 Apr 2018 13:38
I'm restoring a 1976 KZ900 purchased a new built motor with a 1260 kit welded crank not what cams but I believe RC brand. Need carbs I have a set of 28mm pumpers should I step up to 29 smooth bores or 34mm flat sides? Any thoughts.
- DoctoRot
Re: recommendation for carbs on new motor
16 Apr 2018 23:34 - 16 Apr 2018 23:36
Im no engine guru and im sure the 28 pumpers will work but with a 1260 kit i would say let that motor breath and use the 29 smoothies or if you got the coin spring for a set of flatslides. I have RS34 carbs on my 1075 with street port and polish and mild cams and it rips.
Last edit: 16 Apr 2018 23:36 by DoctoRot.
The following user(s) said Thank You: marcumc
- DFIGPZ
17 Apr 2018 17:37
Depending on what the head flows I would rum 36mm if it has a good flowing cylinder head on it.
1984 750 Turbo
