Assembly lube / Valve Clearances
- cg94
15 Apr 2018 12:41
Hi everyone,
I have a 1978 Kz650 SR that I recently got my head back after having a valve job done. I bench shimmed it and it is now assembled with the cams in, but when I retook the measurements it looks like a lot of my clearances are too tight. I used a 50/50 mix of STP and engine oil as an assembly lube. Would the thickness of this mixture effect my readings drastically and cause them to appear tighter than they are? Or was the error in my calculations when I purchased the shims?
thanks!
thanks!
1978 KZ 650 SR
- zed1015
Re: Assembly lube / Valve Clearances
15 Apr 2018 12:54
Bench shimming the head is ok to get in the ball park but once fully assembled and everything is bolted down and settled they nearly always need further adjustment.
15 Apr 2018 13:41
When a valve job is done the valves sink deeper into the head and the clearance closes up. Hopefully your machinist tipped a few thousands off the valve ends to compensate or you will find there is a large shift in the shim range toward the low side.
- cg94
15 Apr 2018 14:00
I'll go ahead and double check my measurements and order the appropriate shims tonight.
The valve job was done well and all the stems were tipped in addition to having new springs and retainers in as well as guides. My number 3 valve could only be tipped so much and is still not within spec, and many of the valves are still low in the shim range despite being tipped. Will I eventually need to replace the seats to restore the valves to a healthy shim range?
1978 KZ 650 SR
- zed1015
15 Apr 2018 14:31cg94 wrote: The valve job was done well and all the stems were tipped in addition to having new springs and retainers in as well as guides. My number 3 valve could only be tipped so much and is still not within spec, and many of the valves are still low in the shim range despite being tipped. Will I eventually need to replace the seats to restore the valves to a healthy shim range?
Going by the book you should try a new stock valve first to see if that gets you back in the range with plenty of shim.
If not then fitting bigger valves (1mm os etc ) will put the valve seating area further out on the unworn part of the seats and should solve the problem ( this is the most common reason these engines get bigger valves and not for performance gains ).
Only after all that fails would you replace the seats.
The following user(s) said Thank You: missionkz
- cg94
16 Apr 2018 11:02
thanks for the info! Does adding larger valves require any other steps? Wouldn't they sit further out and risk hitting the pistons?
1978 KZ 650 SR
- KZB2 650
16 Apr 2018 11:27
Surprised things changed so much after bench shimming...... mine stayed almost exactly maybe only a couple a half a thousands diff...... did em all on the loose side.....did have the head skimmed 4 or 5 thousands though so maybe that helped. Ape did a good job on tipping the valves too as they are all very near the center.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- zed1015
16 Apr 2018 13:53Larger valves will sit at the same height as stock, they just use the wider lesser worn part of the seat .cg94 wrote: thanks for the info! Does adding larger valves require any other steps? Wouldn't they sit further out and risk hitting the pistons?
The valves seats still need cutting and the stem height setting.
The larger heads will mask the ports slightly and the throats are usually enlarged to compensate but you probably wouldn't notice in a stock motor.
