Exhaust gasket
  • gordone
  • Topic Author
19 Mar 2018 12:58 - 19 Mar 2018 13:43 #780457 by gordone
Exhaust gasket was created by gordone
Hi,
When I removed the mufflers it was two gasket for each outlet. One thin, see attached photo and then a thick.
These:
And these:
Is there any point having two ? I was thinking only have the one of each (last picture) ?
The thick was used so It was thinner then the picture, but I don`t have picture of it....
Is there any reasons to use two gaskets ?
Project:
Last edit: 19 Mar 2018 13:43 by gordone.
  • Scirocco
  • Premium Member
19 Mar 2018 14:32 #780461 by Scirocco
Replied by Scirocco on topic Exhaust gasket
The exhaust gaskets squished flat by the first use, (one time use only). Some exhaust ports had a lot of carbon on the sealing surface and are uneven. To be sealing the blow by hot gases it is a common "mod" to get the gap closed on the exhaust port and exhaust header with a second used or new gasket.
Suzuki for example use better exhaust gaskets with a thicker crush component range.
Michael
  • gordone
  • Topic Author
19 Mar 2018 14:40 #780463 by gordone
Replied by gordone on topic Exhaust gasket
Thank you.
So to be 100% sure there is noleak, I can use two new gasket?
I already have 4 kawa oem, need to purchase 4 more then.
Project:
  • Scirocco
  • Premium Member
19 Mar 2018 14:47 - 19 Mar 2018 14:48 #780464 by Scirocco
Clean the port gasket surface first from carbon and use only one gasket.
Last edit: 19 Mar 2018 14:48 by Scirocco.
  • gordone
  • Topic Author
19 Mar 2018 14:49 #780465 by gordone
Will do and take it from there.
Thank you again :)
Project:
  • Scirocco
  • Premium Member
19 Mar 2018 14:51 #780466 by Scirocco
...and don´t over tighten the bolts!!!!!
  • z1kzonly
19 Mar 2018 16:35 #780474 by z1kzonly
Replied by z1kzonly on topic Exhaust gasket
1 new gasket, and I always use some High Temp RTV sealant. (Red or Black Silicone)
  • SWest
  • 10 22 2014
19 Mar 2018 18:05 #780481 by SWest
Replied by SWest on topic Exhaust gasket
I use two with my V/H exhaust. One is not enough.
19 Mar 2018 18:36 - 19 Mar 2018 18:41 #780483 by Dr. Gamma
Replied by Dr. Gamma on topic Exhaust gasket
In all the years I have had Kawasaki bikes, I have NEVER had to use more than one exhaust gasket. Even on my Suzuki bikes, I only needed one exhaust gasket to do the job. I only use O.E.M. factory exhaust gaskets in everything I own or owned over the years.
I just make sure the area where the gasket sits is completely free of carbon. I use a little dab of grease to hold them in place, and tighten down the collars down evenly on both sides. Never had a problem with exhaust leaks there on any of my bikes.
1986 RG500G 2 stroke terror.
Last edit: 19 Mar 2018 18:41 by Dr. Gamma. Reason: badd grammer
19 Mar 2018 18:45 #780485 by Nessism
Replied by Nessism on topic Exhaust gasket
On my 750 with OEM exhaust I spent a LOT of time trying to get the exhaust to seal with only one gasket but failed on a couple of ports. I kept telling myself that I must be doing something wrong but the same thing kept happening. I finally installed a second gasket and the pipes sealed up beautifully. The OEM Kawasaki gaskets are thin and it doesn't take much misalignment to result in a leak. As mentioned, Suzuki gaskets are much thicker, almost twice as thick. That should tell you something right there.
The following user(s) said Thank You: Street Fighter LTD, gordone, Scirocco
11 Apr 2018 10:44 #781672 by BOOM_FIST
Replied by BOOM_FIST on topic Exhaust gasket
So, if one were to want to use the much thicker Suzuki gasket...anyone have that part number??
1977 KZ900A5
11 Apr 2018 11:05 #781673 by kevski
Replied by kevski on topic Exhaust gasket
BOOM_FIST wrote: So, if one were to want to use the much thicker Suzuki gasket...anyone have that part number??
They are generic whichever style you buy, Ebay is a good source for both types, i believe the 900/1000 use 42mm ones, i have only had problems with sealing on one exhaust system, that was a shark racing system i had on a 750 Zephyr, it had no lip on the headers, i resolved this by making aluminum top hat inserts for the headers which increased the area of the mating surfaces, nuts evenly tightened on the collars and not overdone .
