Knocking in neutral, goes away when in gear
  • bryced1
  • bryced1's Avatar Topic Author
19 Feb 2018 10:30
#778998
Hey all,
my 83 kz550 has a recurring clunk/ knock when the motor is running and in neutral. it gets quieter, though still present, when the clutch lever is held (clutch disengaged), but goes away completely as soon as it is shifted into first gear.
Not really sure where to begin checking on this, so any guidance would be greatly appreciated.
Thanks!!
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Knocking in neutral, goes away when in gear
19 Feb 2018 12:52
#779002
Have you synced the carbs?
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
19 Feb 2018 13:31
#779005
Check your timing change tension.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • bryced1
19 Feb 2018 15:46
#779014
I have not synced the carbs, and will look at the timing chain tension.
But neither of those would cause a noise that disappears once shifted into gear, would it?
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
19 Feb 2018 15:56
#779015
bryced1 wrote: I have not synced the carbs, and will look at the timing chain tension.
It just might.
I have seen ( heard ) rattles from these two issues
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
19 Feb 2018 16:06 - 19 Feb 2018 16:07
#779017
It sure would. Without a load (idling in neutral), particularly if the engine is stumbling on one or more cylinders a loose timing chain will slap quite loudly. Once in gear the drag of the transmission alone can be enough to keep the timing chain slack toward the back of the cylinders.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 19 Feb 2018 16:07 by KZQ.
