Where to order COmetic gasket for KZ650 with 810 big bore?
  • Bdog
  • Bdog's Avatar Topic Author
  • Sweep the leg johnny!!!
15 Feb 2018 06:55
#778795
Like the subject says I have not thought about the head gasket in nearly ten years, I need to go ahead and replace the base (which I hope to get from Kawasaki) but I need a good big bore head gasket. Where can I source one of those? I poked around on cometic's site to no avail.
Thanks in advance.
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • KZB2 650
  • KZB2 650's Avatar
Re: Where to order COmetic gasket for KZ650 with 810 big bore?
15 Feb 2018 07:31
#778798
Look on the 4th page for "Head gasket for Wiseco piston 69mm"....... It lists the Wiseco web page where you can pick it up.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Bdog
15 Feb 2018 09:09
#778809
So the Wiseco gasket is Cometic then?
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
  • zukdave
  • zukdave's Avatar
15 Feb 2018 17:45
#778835
Look it up for a KZ/ZX750 there was NEVER an 810 kit for a KZ650
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
