Cam Chain Guide Separated
10 Feb 2018 06:58 #778460 by k1z947060
Cam Chain Guide Separated was created by k1z947060
Hello,
I have a 1976 KZ400 and the cam chain guide (exhaust side/tensioner side) has separated. The plastic/vinyl black piece has come off of the alloy piece. Does anyone know of a suitable epoxy to adhesive these pieces back together?
Thank you,
1976 KZ400
  • Scirocco
  • Premium Member
10 Feb 2018 14:12 #778491 by Scirocco
Replied by Scirocco on topic Cam Chain Guide Separated
In my cool rolled steel company we renew (glue) plastic/vinyl/rubber coatings on aluminum tachometers wheels with a two component glue. It is an oil resistant glue and could only removed on a lathe.
Give me some time for the investigations, i am at work tomorrow and ask for the glue manufacturer.
The following user(s) said Thank You: k1z947060
10 Feb 2018 16:32 #778494 by Jack_Mills
Replied by Jack_Mills on topic Cam Chain Guide Separated
I have the same problem. Same bike too. Wonder if Kawasaki messed up the glue for that batch of bikes. Following
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
Thanks goes out to all folks who share their great knowledge teaching others about classic metric motorcycles.
10 Feb 2018 17:44 #778496 by k1z947060
Replied by k1z947060 on topic Cam Chain Guide Separated
Thanks of the response guys. That glue you mentioned sounds promising. I was worried I was going to be immediately blasted for even considering this instead of replacing it.
The problem is with this cam chain guide I believe you have to pull the motor, split the cases, and take the crankshafts out! Hopefully we will get a solid solution for this.
1976 KZ400
  • SWest
  • 10 22 2014
10 Feb 2018 19:04 #778501 by SWest
13 Feb 2018 05:35 #778673 by k1z947060
Scirocco wrote: In my cool rolled steel company we renew (glue) plastic/vinyl/rubber coatings on aluminum tachometers wheels with a two component glue. It is an oil resistant glue and could only removed on a lathe.
Hello, were you able to find out what glue you use?
Thank you,
1976 KZ400
14 Feb 2018 12:48 #778767 by k1z947060
What do you guys think about these:
1.) Henkel Loctite Hysol E-120HP Epoxy Adhesive 50 mL Cartridge
www.ellsworth.com/products/adhesives/epo...eEAQYAyABEgKI4PD_BwE
2.) DEVCON HP250 YELLOW TWO-PART EPOXY ADHESIVE - BASE & ACCELERATOR (B/A) - 50 ML CARTRIDGE - 14315
www.rshughes.com/p/Devcon-HP250-Yellow-T...G5R:20180214203140:s
3.) Hysol® 1C™ High Temperature High Viscosity Epoxy Structural Adhesive, White, 4oz Kit
www.all-spec.com/Catalog/Adhesives-Seala...JZNfD_BwE#undefined2
1976 KZ400
  • Scirocco
  • Premium Member
14 Feb 2018 13:52 #778769 by Scirocco
Sorry for the delay.
We use this product: WEICON Easy-Mix HT 180
high temperature resistance up to +180°C (+356°F); short term to +230°C (+446°F).
www.weicon.ca/products/adhesives-and-sea...asy-mix-ht-180?c=641
Remove the old glue, rough up both parts, degrease both parts, glue and let it cure for 24 hours.
  • SWest
  • 10 22 2014
15 Feb 2018 07:59 #778799 by SWest
Replied by SWest on topic Cam Chain Guide Separated
I would never put in old plastics, even less ones that has been repaired. Too much damage could be the result.
15 Feb 2018 08:07 #778800 by Jack_Mills
The part on mine isnt damaged. The glue just dried up. The other option is to crack the bottom case, and that sounds like a pain in the ass :(
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
  • SWest
  • 10 22 2014
15 Feb 2018 08:18 #778801 by SWest
In 78 I used a CB 450 cam chain adjuster rod because it was longer instead of replacing the guides and rollers. Bent valves, damaged pistons was the result after the cam chain broke. Wound up going 1015 because it was cheaper than OEM ones but STILL had to pay Full Ripping Retail for the rest of it and had to split the cases anyway. That was a hard $1000+ lesson. There's security in knowing what's going on between your legs.
15 Feb 2018 08:25 #778802 by Jack_Mills
I totally understand the risks involved. Apparently it mustve been a problem on the assembly line to have 2 similar z400 76s both with the same issue. I have a couple spare engines so I am ok if the glue doesnt hold. My buddy has a z1000, and had the same issue, he used some 2 part glue and has held ever since. Guess we can keep our fingers crossed, I do not wanna crack the bottom of this one, but if I do then Im gonna powder this damn engine :)
74 kz400 D1
75 kz400 D2
75 kz400 D2
75 kz400 D2
76 kz400 D3
76 kz400 D3
77 kz400 A1
78 kz400 B1
80 xl80s
81 kz440 B2
81 GL1100
81 xl80s
81 xr80
96 K1100LT
18 HAWK250
