Cam timing one tooth off
  • zed1015
  • zed1015's Avatar
Re: Cam timing one tooth off
11 Feb 2018 11:23 - 11 Feb 2018 11:26
#778541
YAWN!!!!!
Here's the guys second post.
"Thanks for the replies so far...I guess to back up, this motor had been running just fine - but we cracked the cases, so it had to come all the way apart. I didn't really pay attention to the cams at disassembly...assuming they'd be normal, I guess.
So I have to believe that they're degreed correctly...just trying to make sure I know what I'm doing with the markings. "
The motor was running fine regardless of cam spec.
Cams haven't been moved on the sprockets.
Simply confirm the dot is the timing mark.
JOB DONE.
Last edit: 11 Feb 2018 11:26 by zed1015.
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
11 Feb 2018 16:23 - 12 Feb 2018 12:24
#778554
I noticed there seems to be less compression using the kick starter by hand now. I'll recheck the timing. I cleaned up my thread and moved the adverce posts. Please carry on..
Last edit: 12 Feb 2018 12:24 by SWest.
  • SWest
  • 10 22 2014
13 Feb 2018 13:39
#778711
Doesn't run like it has bent exhaust valves.
