'84 KZ750LTD (Shafty) cams timing problem
- Surt
23 Jan 2018 12:55 - 23 Jan 2018 13:00
hi all, im back into my forsaken project of a kz 750 into cafe racer conversion, now i assemble the engine. the bike was in buckets when bought, so ive never seen it running
well, long story short...
when i set cams by the marks
and started to rotate the crank (the tensioners innit as well), i'd heard kinda clicks. so i had to remove the head and seen the scratches on the intake valves made by the outlet valves
thats a mockup setup, all marks were in line, ken oath!
then i looked better into the manual and saw the pic
so i suspect that the outlet cam's sprocket installed through wrong holes.
is it so?
thanks in advance mates!
is it so?
ZN750 Ltd Shaft (non-USA)
Last edit: 23 Jan 2018 13:00 by Surt.
- Surt
Re: '84 KZ750LTD (Shafty) cams timing problem
24 Jan 2018 09:31
alrighty, the probs sorted
- scubaanders
24 Jan 2018 23:37 - 24 Jan 2018 23:38
Guess you realized that you put the exhaust cam in the wrong holes on the sprocket or you have two inlet cams.
Opsi! Take all the valves out and make sure they are still strait and that the valve guides are ok.
/A
Read the manual twice, wrench once.
Inteesting thing that you and exchance the cams and still turn over the engine by hand. Dont ask how I know.
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Last edit: 24 Jan 2018 23:38 by scubaanders.
The following user(s) said Thank You: Surt
- KZB2 650
25 Jan 2018 08:24 - 25 Jan 2018 08:27
Yah Scuba that's what I thought when I read this. At least maybe pour some fuel oil or kerosene in the ports to see if the valves are not bent and leaking..... hoping they are ok. Be sure to clean the bolts holding the sprockets, torgue em to the low end or mid range using a inch lb wrench and use blue loctite on them too. A few that are smarter than me by far say to use green loctite (med strength or red).
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 25 Jan 2018 08:27 by KZB2 650.
- scubaanders
25 Jan 2018 11:27
Yup! Blue locktight or better not remove them unless you ar planning to slot the sprockets inorder to time the cam's.
I am not shure if I would trust the kerosene method, I would remove tve valves in order to make sure their steait. As a lost valve create major damage to the engine.
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- Surt
03 Feb 2018 01:24 - 03 Feb 2018 01:28
thanks for replies mates, yup i somehow mixed up shafts from 2 engines, coz i'd bought a gpz 750 engine as well. now the buggers sorted no wuccas no bends good comp
but i have 2 details left in the box, no idea where are they from, hopefully they got in by chance?
the 1st one is a jet like pipe, 6.3 mm o.d. x 15.6 mm long
and the 2nd one is a pretty big cyl, a stop or plug, 15.1 mm o.d. x 13 mm long
any guess? and thanks heaps in advance!
Last edit: 03 Feb 2018 01:28 by Surt.
03 Feb 2018 05:45
Goes in the starter clutch.
- Surt
03 Feb 2018 08:05
the 1st detail?
- Busy
03 Feb 2018 19:04
- Surt
04 Feb 2018 00:01a hell of a news, and probably the 2nd one is 92122...
and there must be a spring 92081
multiplied by 3
i'll look into my other engine, hopefully the parts fell out from it
and thanks Tex!
- Surt
04 Feb 2018 09:46
sometimes just a lucky bastard! looked into the gpz750 engine and lo!
sorted
btw what is that, a thermostate like thingy? theres nothing like that in the kz sump
sorted
- Busy
04 Feb 2018 11:57
Oil level switch
