kz650 starter clutch solution - ZR7S part
  • telemanvt
  • telemanvt's Avatar
  • Away
Re: kz650 starter clutch solution - ZR7S part
12 Sep 2018 13:01
#790780
Hi!
New to forum and question related to starter clutch substitution for a 1979KZ650D2SR. Do I also need to replace the starter clutch shaft if I was going to use the better designed ZR 7S starter clutch assembly or can I use the original shaft from my KZ 650 and just add the other parts?
Sorry if this is a redundant question for you but before I start the parts search i wanted to be sure.
Thanks in advance!
  • KZB2 650
  • KZB2 650's Avatar
14 Sep 2018 06:55 - 14 Sep 2018 06:58
#790846
Wishing I would a run across this back when I re did mine(4 years ago I think) ....... the older design parts are working fine (replaced all) and should out last me but better is always .....well better.......... o yah and wish I would a layed mine on its side too........ read you could but ti sounded scary to me but after seeing it I could a saved myself a lot of extra work...... even though it was nice to have the motor on the work table again.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 14 Sep 2018 06:58 by KZB2 650.
The following user(s) said Thank You: telemanvt
  • dogerz
  • dogerz's Avatar
14 Sep 2018 11:37
#790865
When I did mine I pulled the front of the bike up using a strap around the frame gusset behind the head stock hung from a beam in my garage ceiling. I got the front up to about 45degrees before the gauges started interfering with the strap. I also took the front wheel off. This provided very easy access underneath and to both sides of the bike. Worked great.
1980 Z750E
  • weeZee
  • weeZee's Avatar Topic Author
23 Sep 2018 23:47
#791337
I don't believe I did. Check how the oil pump gears mesh with the starter clutch shaft, also check the overall length.
I'm hesitant to play expert without the parts in front of me so perhaps somebody else could chime in.
  • jimmybon
  • jimmybon's Avatar
13 Sep 2019 04:03
#810794
I just did the mod on my 650 hybrid, lucky to get a complete ZR 7 gearbox form Europe. Just got all back together and the starter clutch won’t disengage, so it’s jamming I suppose. I made sure I had the spacers in the right spot, the 2mm in the clutch. I would like to brain storm what it could be befor going through the hassle of stripping down again
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
  • Daftrusty
  • Daftrusty's Avatar
13 Sep 2019 06:21
#810798
Without seeing it first hand, I can’t really assume to know what is wrong.
All I can do is post the correct shim thicknesses and in which order they are installed since you only said you put the 2mm one in the “right spot”.
These are the right spots:
If this is exactly how you installed everything, then I am at a loss to explain why it has seized.
Maybe a bit of grit has fouled the operation of the clutch??
If it was me, I would take it all out and solvent wash the sprag mechanism and all the roller bearings, re oil and reinstall.
The following user(s) said Thank You: loudhvx, weeZee
  • jimmybon
  • jimmybon's Avatar
13 Sep 2019 16:28 - 13 Sep 2019 16:28
#810819
Thanks for your thoughts Draftrusty. I think I'll take out the starter motor and see if I can free it up through the idler gear. I definitely have 2 x 3.2mm spacers left over from the swap. Even if I was to get the position of the 2mm and 3.2mm back to front, it should only miss aline the gear to Idler gear
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
Last edit: 13 Sep 2019 16:28 by jimmybon.
  • jimmybon
  • jimmybon's Avatar
17 Sep 2019 03:30 - 17 Sep 2019 03:31
#810954
This fix on my stater clutch has opened up a can of worms, I’m guessing the first time you installed your’s Daftrusty, you had it right to the parts lists and drawings online.
I swapped the spacers with the 2mm outside and the 3.2mm inside the coupling and found the starter gear runs freely.
I compared the measure from clutch gear to the starter gear on the old and the new and their now the same
74 Z1A900 original
74Z1A900 barn find
77 Z650B1 Hybrid
S1000xr
Last edit: 17 Sep 2019 03:31 by jimmybon.
  • BlackEyeCafe
  • BlackEyeCafe's Avatar
13 Jul 2020 15:23
#830595
Would a 90's ZR550 starter clutch be a suitable option? Seems to be nearly identical parts list
1977 KZ650 C
Jets - Main 115 - Pilot 17.5 - Needles - Position 3 - NGK BR7ES
  • Daftrusty
15 Jul 2020 10:12
#830741
BlackEyeCafe wrote: Would a 90's ZR550 starter clutch be a suitable option? Seems to be nearly identical parts list
No. The zr550 uses the exact same 3-roller style clutch as the 650/750 but they are a different size and not compatible.
The following user(s) said Thank You: BlackEyeCafe
  • ZX750A
  • ZX750A's Avatar
31 Dec 2022 20:19
#878397
Hi All, sorry if this is a stupid question or has been asked elsewhere.  Will this solution work on a GPz750 (ZX750A) as well as the z650?
Cheers, my starter clutch is gone and I want to get it running this summer.
  • Daftrusty
05 Jan 2023 15:33
#878585
Yes. Both the 650 and 750’s share the exact same secondary shafts and 3 roller starter clutch. So the zr-7 starter clutch upgrade can be done to both in exactly the same way.
The following user(s) said Thank You: ZX750A
