Do KZs from the late 70s have asbestos gaskets?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Do KZs from the late 70s have asbestos gaskets?
08 Jan 2018 17:29
#777086
:lol: :lol: :lol: :woohoo:
  • chikosneff
  • chikosneff's Avatar Topic Author
10 Jan 2018 10:23 - 10 Jan 2018 10:25
#777154
Update: cleaning the mating surfaces from this 40 years old gasket residue really kicked my ass! It took me probably 3 hours and I hated every moment of it. I tried permatex gasket remover and it was completely useless. Carb cleaner, brake cleaner, and WD40 helped a little but nothing seemed effective in melting the gasket and the gunk down. If you have products that are known to work please let me know so that next time I'll have to do this I won't work as hard.
1978 KZ400 B
Last edit: 10 Jan 2018 10:25 by chikosneff.
  • Nessism
  • Nessism's Avatar
10 Jan 2018 11:52
#777156
The old style Permatex gasket remover spray worked okay. It still required several applications with dwell time to allow it to work, but it did help soften the gasket some. The new "low VOC" formula is pure junk though. Some people say heavy duty paint stripper works okay. I've tried it but didn't wait long enough to pass judgement. Sadly, that's all I got in terms of suggestions. Those old gaskets can really petrify themselves and are a bitch to remove.
The following user(s) said Thank You: chikosneff
  • chikosneff
10 Jan 2018 12:25
#777159
Nessism wrote: The old style Permatex gasket remover spray worked okay. It still required several applications with dwell time to allow it to work, but it did help soften the gasket some. The new "low VOC" formula is pure junk though. Some people say heavy duty paint stripper works okay. I've tried it but didn't wait long enough to pass judgement. Sadly, that's all I got in terms of suggestions. Those old gaskets can really petrify themselves and are a bitch to remove.
"Petrify" is the right word! :D I used a stainless bristle brush with my rotary tool. From the looks of it, I believe that the grit was fine enough and the surface is nice and smooth now. I was scared to use it but it wasn't too aggressive at all.
1978 KZ400 B
  • bluej58
  • bluej58's Avatar
11 Jan 2018 03:16
#777188
I use sharp ( Sharp) single edge razor blades and a fine sharpening stone to flatten the area around the screw holes that mushroom up a bit .
78 KZ1000 A2A
  • ayeckley
  • ayeckley's Avatar
11 Jan 2018 03:56
#777189
I use a piece of copper sheet (not brass) or polycarbonate sheet as a scraper. Stiff enough to remove petrified gasket material but almost no chance of scratching the aluminum or embedding dissimilar metal into it.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
11 Jan 2018 05:44
#777192
Plastic putty knives are available at nearly any hardware store. I would not expect them to scar aluminum, but they are pretty stiff, so they should remove stubborn gaskets if the gaskets have been soaked with gasket remover. Ed
  • Nessism
  • Nessism's Avatar
11 Jan 2018 09:37
#777200
You guys suggesting a plastic scraper must have never removed a petrified base gasket.:blink:
  • ajsfirehawk
  • ajsfirehawk's Avatar
11 Jan 2018 09:52
#777201
Nessism wrote: You guys suggesting a plastic scraper must have never removed a petrified base gasket.:blink:
I bought a gasket scraper and plastic razor blades. They don't work for me. Gasket removal is by far the most hated task for me on these bikes. I've spent 6 to 8 hours getting the base cylinder gaskets and cam cover/head gaskets cleaned off properly. This destroys my ability to use my hands for the next 48 hours. This last time I had time to let chemicals do more of the work since I can't ride in the winter. I applied CRC gasket remover, let it soak for 30 mins or so, scrape, remove repeat. Still tedious as all get out but it worked with far less damage to my hands. The last two bikes I've opened up this year have a very thin layer of black gasket seal as well. Wicked stuff to remove without hosing up the delicate aluminum surfaces.
I've considered having them hot tanked in an aluminum friendly chemical mixture, but haven't gotten off my butt to find out who could do it and if it would be effective. Just an evil task.
PS - CRC gasket remover isn't sitting on the shelf at the auto parts store. You have to ask for it as they keep it behind the counter due to the harsh nature of the chemicals.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
  • bluej58
  • bluej58's Avatar
11 Jan 2018 17:57 - 11 Jan 2018 18:02
#777216
Nessism wrote: No disrespect guys but it takes long term exposure to high quantities of asbestos to cause health effects.
I had an old girl friend that died in her twenty's of asbestos poisoning from dust in her basement apartment.
I think in most cases you are right, back in the 70's I was doing a lot of remodeling that involved asbestos siding work and 8" floor tile removal.
We never wet it down or wore respirators and I'm still here.
I worry a lot about what in my lungs these days, that stuff doesn't come out, emphysema is one of the worst ways to go, it takes years of progressive suffocation before it finally kills you.
I watched my father in law die from it, NO THANKS
I'm still doing carpentry and work around a lot of dust, especially in the Winter when the houses are closed up, it really gets to me.
These days I wear a good mask and hearing protection, but my ears are trashed anyway.
Still haven't learned my lesson about chemical ex poser though.
78 KZ1000 A2A
Last edit: 11 Jan 2018 18:02 by bluej58.
  • ayeckley
  • ayeckley's Avatar
12 Jan 2018 03:22 - 12 Jan 2018 03:34
#777228
Nah, I've removed several (not dozens or hundreds) of very old gaskets. I'm specifically talking about polycarbonate, not acrylic so I'm not talking about a plastic paint stirrer or something like that. Anyhow, the copper works better of course so i prefer that, but if you've got a chunk of Lexan sheet laying around why not try sharpening up the edge and give it a shot?
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1
1973 CL350K4
1969 CT90
2006 Burgman 400
Last edit: 12 Jan 2018 03:34 by ayeckley.
  • ezrider714
  • ezrider714's Avatar
13 Jan 2018 20:32
#777263
Shhh...MEK
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
