Plastic clots cylinder block
- zed1015
Re: Plastic clots cylinder block
13 Dec 2017 02:34 - 13 Dec 2017 07:01
These ones in the base of the block do nothing to help dampen fin vibration.
To reduce fin ringing they would need to be inserted between the fins.
These ones are only plugs which serve to prevent muck building up in the holes which could drop in to the crankcase when lifting the barrels as they are close to the mouth of the cylinders.
The holes were originally used to locate the blocks on a fixture at the factory for machining operations.
From a mechanical point of view you can leave them out, leave them as is or bung the holes with something else.
Last edit: 13 Dec 2017 07:01 by zed1015.
- gordone
13 Dec 2017 13:31zed1015 wrote: These ones in the base of the block do nothing to help dampen fin vibration.
Thank you for advise, in other word, I don`t do anything and just leave the existing plugs in the whole
Project:
Project:
- zed1015
13 Dec 2017 13:34
Yes! Just leave them in.
- PaintWorkz
20 Dec 2017 07:31zed1015 wrote: These ones in the base of the block do nothing to help dampen fin vibration.
Ya learn something every day on here!
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
84 Gpz900 street
77 1135 KZ900 A5
