Plastic clots cylinder block
  • gordone
  • gordone's Avatar Topic Author
11 Dec 2017 23:09
#775878
Hi,
Please see attached picture, what is the function behind these plastic clots and do I need to replace the one is not 100% good?
Thank you.
Project:
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Plastic clots cylinder block
12 Dec 2017 04:01 - 12 Dec 2017 04:03
#775879
Anti vibration dampers, for noise attenuation on the cooling fins, older two strokes with big fins often had that ringing sound..
They do crop up nos sometimes -yes I'd replace it.
Last edit: 12 Dec 2017 04:03 by Tyrell Corp.
  • TexasKZ
  • TexasKZ's Avatar
  • Away
12 Dec 2017 04:15
#775881
I wonder if rtv could be substituted?
  • martin_csr
  • martin_csr's Avatar
Last edit: 12 Dec 2017 06:03 by martin_csr.
  • gordone
12 Dec 2017 06:42
#775886
Thank you, there are 6 in total?
www.partzilla.com/catalog/kawasaki/motor...-pistons-kz750-h2-h3
I don't have access to the block now, so that is my reason for my question :)
Project:
  • martin_csr
12 Dec 2017 08:57 - 12 Dec 2017 08:57
#775894
Apparently. 6 damper plugs are listed at Kawasaki.com for the 750-E2.
www.kawasaki.com/Parts/PartsDiagram/134869/1981/KZ750-E2
Last edit: 12 Dec 2017 08:57 by martin_csr.
  • gordone
12 Dec 2017 11:06
#775909
So these shall be better and cheaper?
Must I cut them or something, they must be flat the same way the original (even with the alu surface) ?
Project:
  • Nessism
  • Nessism's Avatar
12 Dec 2017 11:26
#775910
Those rubber plugs are dampers and as such, the hardness and damping properties of the rubber affect their use. If you use something softer/harder it will change how they function. Doubt it matters a whole lot though. I forgot to install them back when rebuilding my 750 and if they make a difference, I can't notice.
  • gordone
12 Dec 2017 11:28
#775911
hehe okey :)
Everything cost money, so If I can save something..... heh
WIll you asked the yellow one on ebay ?
Project:
  • Dr. Gamma
  • Dr. Gamma's Avatar
12 Dec 2017 12:19
#775915
I have never put them back in any motor that I have put back together since way back in 1976!!!
The purists will say you have to use them. I never noticed any difference in my motors without them!!!
1986 RG500G 2 stroke terror.
  • martin_csr
12 Dec 2017 13:02 - 13 Dec 2017 05:10
#775917
Gordone, before reading this, read comment by Dr. Gamma. hee.
I have no idea if the silicone plugs would work the same as stock. See reply by Nessism.
I don't know if they would fit. The taper may not be correct. I don't know. I would compare them to a new oem plug.
If the taper is correct, you might have to trim or cut them. no big deal. I would use a sharp razor blade.
Since Dr. Gamma says they aren't really needed, I would probably use the silicone plugs. assuming oem are too expensive or unavailable.
Or just fill the holes with high temp rtv as TexasKZ said.
Last edit: 13 Dec 2017 05:10 by martin_csr.
  • zukdave
  • zukdave's Avatar
12 Dec 2017 19:08
#775941
My ZX750A1 (GPZ750) motor does not have them.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
