Plastic clots cylinder block
- gordone
11 Dec 2017 23:09
Hi,
Please see attached picture, what is the function behind these plastic clots and do I need to replace the one is not 100% good?
Thank you.
Thank you.
Project:
Project:
- Tyrell Corp
Re: Plastic clots cylinder block
12 Dec 2017 04:01 - 12 Dec 2017 04:03
Anti vibration dampers, for noise attenuation on the cooling fins, older two strokes with big fins often had that ringing sound..
They do crop up nos sometimes -yes I'd replace it.
Last edit: 12 Dec 2017 04:03 by Tyrell Corp.
12 Dec 2017 04:15
I wonder if rtv could be substituted?
12 Dec 2017 05:55 - 12 Dec 2017 06:03
Maybe use high temperature silicone rubber plugs? guessing those are 10mm.
KAWASAKI KZ DAMPER PLUG OEM NOS PT# 92066-1016 OM7 --- OEM
(50) 1/4" x 3/8" High Temp Silicone Rubber Plugs Powder Coat Coating Paint Mask ... 3/8" = 10mm
16pc High Temp Silicone Rubber Tapered Plug Kit Powder Coating Paint Masking Set --- Assortment ....various sizes
Last edit: 12 Dec 2017 06:03 by martin_csr.
- gordone
12 Dec 2017 06:42
Thank you, there are 6 in total?
www.partzilla.com/catalog/kawasaki/motor...-pistons-kz750-h2-h3
I don't have access to the block now, so that is my reason for my question
Project:
Project:
12 Dec 2017 08:57 - 12 Dec 2017 08:57
Apparently. 6 damper plugs are listed at Kawasaki.com for the 750-E2.
www.kawasaki.com/Parts/PartsDiagram/134869/1981/KZ750-E2
Last edit: 12 Dec 2017 08:57 by martin_csr.
- gordone
12 Dec 2017 11:06
So these shall be better and cheaper?
Must I cut them or something, they must be flat the same way the original (even with the alu surface) ?
martin_csr wrote: Maybe use high temperature silicone rubber plugs? guessing those are 10mm.
various sizes
Project:
Project:
12 Dec 2017 11:26
Those rubber plugs are dampers and as such, the hardness and damping properties of the rubber affect their use. If you use something softer/harder it will change how they function. Doubt it matters a whole lot though. I forgot to install them back when rebuilding my 750 and if they make a difference, I can't notice.
- gordone
12 Dec 2017 11:28
hehe okey
Everything cost money, so If I can save something..... heh
WIll you asked the yellow one on ebay ?
Project:
Project:
- Dr. Gamma
12 Dec 2017 12:19
I have never put them back in any motor that I have put back together since way back in 1976!!!
The purists will say you have to use them. I never noticed any difference in my motors without them!!!
1986 RG500G 2 stroke terror.
12 Dec 2017 13:02 - 13 Dec 2017 05:10
Gordone, before reading this, read comment by Dr. Gamma. hee.
I have no idea if the silicone plugs would work the same as stock. See reply by Nessism.
I don't know if they would fit. The taper may not be correct. I don't know. I would compare them to a new oem plug.
If the taper is correct, you might have to trim or cut them. no big deal. I would use a sharp razor blade.
Since Dr. Gamma says they aren't really needed, I would probably use the silicone plugs. assuming oem are too expensive or unavailable.
Or just fill the holes with high temp rtv as TexasKZ said.
Last edit: 13 Dec 2017 05:10 by martin_csr.
- zukdave
12 Dec 2017 19:08
My ZX750A1 (GPZ750) motor does not have them.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
