- Thank you received: 30
FittingOil pressure Light to 80's GPZ oil pan
- Wozza
My plan is to drill/tap my spare oil pan to fit a 5psi idoit light switch .
1982 KZ550H1
- ayeckley
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
- loudhvx
- Thank you received: 1616
The 550's do not have that port. The switches are on the oil pan.ayeckley wrote: I can't speak specifically to the GPz550, but the GPz750 has an existing port under the ignition cover for an oil switch. It normally has a threaded plug installed but is used on the KZ750 model. Perhaps the GPz550 has the same provision.
I wonder if there is an oil plug somewhere on the crankcase that can be swapped with a pressure switch.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Thank you received: 1656
The ZR550 uses the same oil pan gasket (11060-1057), and from eb photos the oil pan appears to be very similar.
The Zephyr has an oil pressure switch & oil cooler. and the mountings seem to be the same as the earlier 550 models.
ps: did you use the factory service manual to troubleshoot the problem? It probably has fairly detailed procedures & flow charts.
- Wozza
Yes its definitely a fault in the LCD warning light panel. The FSM helped me pinpoint the fault quickly, unfortunately it says to replace the panel.martin_csr wrote:
Being as its just the oil level light I'm not really concerned about it and think the oil pressure light will be a better fix.
Thanks for the tip on the ZR pans I will look into it.
1982 KZ550H1
- Wozza
The only ones I can find are the main oil gallery plugs the service manual says to use when doing the oil pressure test. .. That point would work but its not very discrete.loudhvx wrote:
1982 KZ550H1
- loudhvx
1981 KZ550 D1 gpz.
Other links.
- Wozza
This might be a straight swap for someone wanting a oil pressure port,, as I have access to bspt taps i will just modify the one i have
On the ZR550 pan below you can see the spot where the oil level sensor hole would be machined. (green Circle)
the oil sensor gets its feed from the large hole where the oil filter goes (red circle).
Heres a GPZ550H pan with no oil pressure sensorr hole
On the other side of the GPZ pan you see the lump (arrow) where a oil pressure sender hole would go as on the earlier and later pans
KZ550 pan with oil pressure sensor but without the oil cooler ports for comparison
1982 KZ550H1
- loudhvx
That's interesting that the pressure switch just measures the pressure in the filter housing. Seems like you should be good to go then... just a drill and tap job, correct?
By the way, if the gauges are messed up, how are you going to use the pressure sender? Just adding on a light somewhere else?
1981 KZ550 D1 gpz.
Other links.
- Wozza
I thought is it was unusual, but the FSM confirms that the oil pressure is being monitored before the oil passes through the filter and into the gallery's..
Correct I will drill/tap for the sensor and mount one of those super bright panel mount LED's somewhere behind the fairing out of the way but visible when it lights up.
Its the only thing on the dash that doesn't work . maybe down the line I might look into it a bit more or not.
1982 KZ550H1
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
I can take pictures of mine if needed.
'85 GPz550(ZX550-A2)
