NEED HELP 81 kz1000j power loss at high rpms
  • Nicky_cruz
  • Nicky_cruz's Avatar Topic Author
11 Nov 2017 08:48
#774447
I have an 81 kz1000 j model. It runs great untill i roll into higher rpms. Its smooth till the last quater throttle and it's just coughing and spitting. I think it's a fuel issue. Any help would be greatly appreciated.
  • ajsfirehawk
  • ajsfirehawk's Avatar
Re: NEED HELP 81 kz1000j power loss at high rpms
11 Nov 2017 09:53
#774450
If you are going lean at high rpms your spark plugs should have a brownish powdery look to the tips.. If they are dark you may well have a spark issue. Coils could be weak or bad and can't recharge fast enough to have a full charge at high rpm. Any of the circuitry in the coil wiring could have a marginal connection (for many reasons, oxidation, loose connection, etc) I'd run it again, create the missing condition and then pull the plugs right away. If they aren't brownish powdery, check the voltage at your coils. You should see north of 12v.
For reference: www.tuningmatters.com/how-tos/beginners-...-carburetor-setting/
79 KZ650 SR
80 KZ1000 Z1 Classic
83 KZ1100 LTD
Z900RS
23 Mach 1
  • Nicky_cruz
11 Nov 2017 11:56
#774457
Thank you I'll check it Sunday morning. I'm running the stock tdi and 3ohm dyna coils. Of that makes any difference.
  • ajsfirehawk
11 Nov 2017 12:16
#774458
That is a very good setup. (Dyna and tdi) Providing the proper voltage is reaching the coils. Your problem may well be fuel. You have to determine if it is fuel or fire (spark) and then chase it down which is why I lined out the two steps to try to determine which issue to run down.
79 KZ650 SR
83 KZ1100 LTD
Z900RS
23 Mach 1
11 Nov 2017 13:26
#774461
Does the bike have the stock air box and filter and stock carb jetting? Ed
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
11 Nov 2017 15:09
#774463
Check the fuel flow through the petcock and float bowl high.
A clogged filter or fuel line filter cause a low fuel flow and lean the mixture on high rpms.
Michael
  • Nicky_cruz
15 Nov 2017 23:10
#774666
Thank you I'm gonna pull the carbs Sunday the rear brake pump went out spent all weekend trying to get it working again. I had brownish plugs all dry. I'm running a V&h 4 into 1 and pod filters the frame has been modified too much for it to for now. What is the stock jet size? And anyone got any idea where i should be with those mods? The guy that owned it before me didn't really take care of it out a bunch of parts on and let it sit.
  • ajsfirehawk
18 Nov 2017 17:39
#774780
Service manual says pilots are 37.5 and mains are 127.5 for J models.
79 KZ650 SR
83 KZ1100 LTD
Z900RS
23 Mach 1
  • Nicky_cruz
22 Nov 2017 15:27
#774942
This is gonna sound ignorant but is the 127.5 the stock size or the size I should be at?
  • ajsfirehawk
22 Nov 2017 19:53 - 22 Nov 2017 20:08
#774954
127.5s are the stock setup for model J's
79 KZ650 SR
83 KZ1100 LTD
Z900RS
23 Mach 1
Last edit: 22 Nov 2017 20:08 by ajsfirehawk.
  • Nicky_cruz
25 Mar 2018 14:46
#780799
I found that the pilot jets were blocked off by a plug is that a normal thing? It wasn't glued or anything just pushed in it looked legit made for the hole spot but I don't see why you'd block off your pilot jets.
  • TexasKZ
  • TexasKZ's Avatar
25 Mar 2018 17:42
#780809
