GPZ550 Vacuum switch/valve?
- blackumi
13 Oct 2017 11:47 - 14 Oct 2017 08:33What exactly does this piece do, and is it necessary?
I'm assuming it's for the factory airbox, but I'm unsure since my bike came with pods installed from the previous owner.
The engine is from an 81
pic from google
1983 GPZ 550
1986 Toyota Corolla AE86
Last edit: 14 Oct 2017 08:33 by blackumi.
- M_a_t_t
Re: GPZ550 Vacuum switch/valve?
14 Oct 2017 07:20
It looks the same as the vacuum switch on my bike (83 KZ1100). Its for emissions and can be deleted as long as you plug up the openings for the hoses. That's what I've seen on other kz1100's (or KZ1000's) anyway. Without the factory air box it is not connected to anything is it?
kzrider.com/forum/3-carburetor/605822-re...rol-on-kz1000-police
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
The following user(s) said Thank You: blackumi
- blackumi
14 Oct 2017 07:47
Ah nice, looks like PO already did half of that.
The breather hoses are still connected to it, but there aren't any vacuum hoses going to it so it's not doing anything.
I'll finish that job and remove all that
1983 GPZ 550
- loudhvx
14 Oct 2017 09:23
In case it isn't, make sure the breather on top of the transmission is able to breathe. Sometimes people mistakenly plug that too, but it must be open.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- blackumi
14 Oct 2017 09:55loudhvx wrote: In case it isn't, make sure the breather on top of the transmission is able to breathe. Sometimes people mistakenly plug that too, but it must be open.
Yes, you're right. That one I planned on positioning a hose over the chain
1983 GPZ 550
