Exhaust smoking really bad
- Kawi-problems23
- 1980 Kawasaki kz250 single cylinder
30 Aug 2017 09:54
Hello everyone
My exhaust is smoking pretty bad i know it's burning oil because of the blue smoke but I'm not too sure where it's burning it in the engine any help would be greatly appreciated
Thanks
Thanks
- zed1015
Re: Exhaust smoking really bad
30 Aug 2017 10:09
Consistent smoke = worn rings /bores . "May" get away with a hone and new rings but maybe needs a re-bore depending on mileage and wear.
Also head gasket failure between the bore and an oil gallery can produce the same symptoms.
Smoke on acceleration = Guide seals and possibly worn guides . "May get away with fresh guide seals but again depending on wear and mileage may need fresh guides and possibly valves.
- Kawi-problems23
30 Aug 2017 10:21
The bike has 220000 kilometres or about 137500 miles. How difficult would it be to get the valves and rings changed? And can you explain what and where the bores are?
30 Aug 2017 11:39
137,500 miles? What kind of bike are we talking about here and has it ever been rebuilt?
- Kawi-problems23
30 Aug 2017 11:46
It's a kawi kz250 single cylinder and I have no idea but i just called a motorcycle shop to see how much it would cost to change the rings and they said $2000 so either I have to do it myself (wich I have no idea how to do) or scrap the bike
30 Aug 2017 12:33
You can do it yourself with a little help here.
- Kawi-problems23
30 Aug 2017 12:50
Alright Thanks I'm not sure how to fully diagnose the problem. The bike runs and drives fine but the engine puffs out blue smoke as soon as I turn on the bike and it bellows out a huge cloud when I rev the engine
- slmjim+Z1BEBE
30 Aug 2017 12:59
Hi Kawi-problems23,
Are you sure the motor oil isn't way over full?
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Kawi-problems23
30 Aug 2017 13:03
Yeah it calls for 1.1 litres of oil and I put in around 825 ml in and 175 or a product called no smoke
- loudhvx
30 Aug 2017 13:24
Wow, that is an amazing amount of miles for such a small single. Hope you can fix it.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- ajsfirehawk
30 Aug 2017 18:14
I'm no clear on the year so availability of parts and other motorcycles isn't clear to me. It is an impressive mileage achievement. I think you should find another one, check the compression and do a motor swap. Way cheaper than where you are headed assuming it is newer than mid 70's.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
- Kawi-problems23
31 Aug 2017 21:14
It's a 1980 kz250 single and I can't find a motor for it anywhere if I can't find one soon I think I'm going to change the rings, valves, head gaskets, and whatever has to be redone over the winter
