Valve spring seat removal methods
  • Markovich
  • Markovich's Avatar Topic Author
29 Aug 2017 15:43
#769954
Hi all, so I'm working on the head now. Going to replace seals, lap valves, clean it up and paint it. While taking it apart and after removing the springs and seals I noticed the spring seats. I was able to fairly easily remove five of them but the other three are being a pita. I used a couple of magnets to get the five off. Looking for some ideas on how to best remove the remaining ones. Thanks, Keith
1990 KZ1000P, 72k miles, 10 years in storage, new, bars, tires, chain and sprockets, seat, carbs cleaned, police equipement removed.
  • baldy110
  • baldy110's Avatar
Re: Valve spring seat removal methods
29 Aug 2017 16:53
#769959
Why do you want to remove the seats, was there an issue with them?
  • SWest
  • SWest's Avatar
  • 10 22 2014
29 Aug 2017 18:55
#769964
Check the valve guides for excessive play. If OK leave them alone.
  • zed1015
  • zed1015's Avatar
30 Aug 2017 00:01 - 30 Aug 2017 00:01
#769978
They only sit loosely in the bottom of the bucket bore and should just lift out on the end of a magnet or drop out if you turn the head upside down.
Some times they stick a bit due to oil being underneath them and a bit of a squirt with petrol or WD should wash off the oil and release the suction.
Last edit: 30 Aug 2017 00:01 by zed1015.
The following user(s) said Thank You: PLUMMEN
  • Markovich
30 Aug 2017 11:55
#770006
Thanks for the info guys. I was cleaning things up so when I noticed some loose and others tight I figured they needed a bit of cleaning. I know a bit OCD of me. Once I removed the ones I could I found what looks like old hardened oil residue. I assume the heat baked it over time. Anyway, I'll get them out and then onward. ☺️
