riding past redline
Re: riding past redline
25 Aug 2017 05:39
The 750 Turbo, which used virtually the same bottom end as the 650, is a testament to the strength of that family of engines bottom end. The 550 is a different beast though. Again, I'm not expert on those engines but rod bearing failures were at least somewhat common. Surely one of the 550 racer guys here knows the history? Probably related to oil supply?
- les holt
25 Aug 2017 10:43
Oil supply is exactly why they would fail on the crank. The design of that bottom end is nearly bullet proof! I'v killed 1 650 and 2 750 bottom ends. They will spin to the moon but, past redline isn't all bad but way past isn't good. Put valve springs in it, keep lash adjusted well, get some track time and study those tickets!!! guessing first gear change will be higher in the rpm range and get lower as you go thru the gears. Like someone said, these are a but a tool to speed, you go faster, you wear things out and break shit!
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- 80B4
26 Aug 2017 15:31
If you are using an OEM tachometer, it is no more accurate than the OEM speedometer. You are probably not actually running it past the redline.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- zukdave
26 Aug 2017 16:41
My AutoMeter 5" monster tach is pretty damn close to reading true rpm's
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- loudhvx
26 Aug 2017 18:15
I think the original poster is referring to a Zr550, so I don't know how relevant Kz550 HP info would be, especially without stock exhaust and intake.
I know I regularly rev the Gpz (Kz550D) past the 9500 redline, and it is still pulling past that. What else you gonna do when you're already in top gear?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
26 Aug 2017 19:22loudhvx wrote: I think the original poster is referring to a Zr550, so I don't know how relevant Kz550 HP info would be, especially without stock exhaust and intake.
EXCELLENT OBSERVATION!!!
You are absolutely correct. The 550 Zephyr (ZR550) makes 49 hp at 10,000 rpm (see link below), and that is a much higher rpm than the KZ550 engine's maximum power, so the chart I posted earlier is irrelevant. Thanks for the correction! Ed
www.motorcyclespecs.co.za/model/kawasaki...asaki_zepher_550.htm
- Zaddict
- Enjoying my Zaddiction!
27 Aug 2017 09:05
yeah, sorry, should have specified - 1990 zr550 B1.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
