Kz650 kickstart help
  • dms137
  • dms137's Avatar Topic Author
20 Aug 2017 14:18
#769308
I paid a guy 400 dollars to replace my starter clutch. After he "finished" He tells me buy a new battery it will fire right up. Well i do that and what you know clutch still slipping and grinding like before.
So anyway i notice the sight glass was empty. I put 3 quarts almost 4 quarts in. Big mistake. I was able to crank it 1 or 2 times.. Let it idle and oil was pouring out everywhere from the crankcase breather. So i pulled the plug.. Syphened about 2 quarts out and the oil level is still high. Now i cant even kickstart the bike and if for some miraculous reason it starts.. The bike will just bog down and shut off after giving it gas. I plan on taking more oil out tomr. Also i put the bike in 1st gear cranked it and the bike rolled forward. Not sure what to do spent like all my money trying to get this on the road and its just nothing but a fuckn headache.
Southern Maryland
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Kz650 kickstart help
20 Aug 2017 14:38 - 20 Aug 2017 15:12
#769309
It look like your specialist mechanic overfill the engine with a lot more oil as necessary.
Out of my memory 3500 ml = 3,5 Liter = 3.7 Quart (USA) = 0,925 Gallon (USA)
The view glass in the clutch cover have to show half filled with oil when the bike is on the main stand.
Be careful your engine sucks oil into the combustion camber over air filter body.
Liquids can“t be compressed like gases an will destroy your engine (Piston cracked and crank rods bend)
Pull the plugs and clean the complete intake part, air filter , air filter body, breather, combustion camber with compressed air.
BTW: get your money back and let you show the old parts he have replaced, i will do so!!!
No good mechanic will give away a bike unproved like this, (sorry to say,), loco mechanic.
He play Russian roulette with the life and health of people like you..
Last edit: 20 Aug 2017 15:12 by Scirocco.
  • dms137
20 Aug 2017 15:31 - 20 Aug 2017 15:36
#769311
Thats for the help.. I changed the clutch lever to like a basic bike lever with no lock screw is that ok?
Also i have pods now. So no airbox.. How do i clean inside the spark plug holes? And the breather is just a hose and screen taped on ill def clean that tomr
Damn i dont even have air compressor.
Southern Maryland
Last edit: 20 Aug 2017 15:36 by dms137.
  • JWKZ750
  • JWKZ750's Avatar
20 Aug 2017 15:38
#769312
dms137 wrote: Thats for the help.. I changed the clutch lever to like a basic bike lever with no lock screw is that ok?
Where are you located?
  • dms137
20 Aug 2017 15:41
#769313
I am in southern maryland. No shop will work on it.. And ive delt with 2 craigslist phonies now.
Southern Maryland
  • JWKZ750
  • JWKZ750's Avatar
20 Aug 2017 15:44
#769314
dms137 wrote: I am in southern maryland. No shop will work on it.. And ive delt with 2 craigslist phonies now.
Sounds like the mechanic didnt do any work at all. Dont feel bad. Some of us have been there. Dont start that bike until you have that oil level right. As another posted said, you could have damaged the engine.
Take a deep breath and relax. You will get your bike back on the road!
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
20 Aug 2017 16:20 - 20 Aug 2017 16:24
#769315
You need absolute a service manual
Get this and read and learn more about your bike and how to handle your problems the right way..
www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
We all her ( me too ) learned the lesson and paid the errors we do with a lot money like you.
All my cars and bikes never seen a mechanic or repair shop in the last 35 years.. I can use my money for better things.
Ask here if you need more help, this forum is very helpful.
BTW, some pics of your bike are helpful too,you have to know, we all here love bike pics.
Last edit: 20 Aug 2017 16:24 by Scirocco.
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Aug 2017 19:03
#769329
Welcome, don't get discouraged. We all have to start someplace.
  • dms137
20 Aug 2017 19:51 - 20 Aug 2017 19:59
#769330
Theres one of the clutch lever... With no lock nut so not sure how to adjust clutch.
Bike pic.. The pods arnt on at the moment cause i was sprayin starter fluid prayin for somethin. And the the ghetto crankcase breather
Frame cut waitin for seat in the mail. And tank primed ready for paint
Turn signals wont blink (led type) changed one of the solenoids? To triton.. Im guessin i have to change both?
Southern Maryland
Last edit: 20 Aug 2017 19:59 by dms137.
20 Aug 2017 20:11
#769332
Frame cut. Congratulations - your bike now has independent rear suspension. Oh wait - that's good on a car / bad on a bike. You need to find someone who can weld because that little piece of original sheet metal connecting the frame rails isn't adequate to keep the rails aligned when you're riding. Ed
  • dms137
20 Aug 2017 20:26 - 20 Aug 2017 20:27
#769334
I know im so proud of myself! Lol. Actually theres 2 bars one alittle closer to the battery. I was gonna cut that piece off you have circled. I dont think it will be an issue.. Maybe one day ill weld a hoop but i gotta be able to ride it to a weld shop first. No truck/trailor
Southern Maryland
Last edit: 20 Aug 2017 20:27 by dms137.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
21 Aug 2017 01:39 - 21 Aug 2017 01:42
#769340
Your rear frame is very unstable and your rear shocks are too short!! When you hit the next road hole your tire hit the rear frame bracket!! This can cause a real bad road accident by a blocking wheel or ripped rear tire!!
Be careful with it.
Last edit: 21 Aug 2017 01:42 by Scirocco.
