1981 Kz650 running rough. looking for suggestions
- Trumpology101
I took the carbs apart and cleaned them so far, replaced the spark plug wires, ran some sea foam through the engine.
Before replacing the wires it was bogging down after I rode for about 15 minutes to the point where it had zero torque. The new wires helped a bit but it just has no go. It revs super high as soon as I accelerate and has a real high pitched sound in it.
Is this just needing to rebuild the carbs entirely. I've never checked engine compression before so I'm not sure how that's sitting either. I recorded a few seconds and uploaded it to YouTube. If anyone has any suggestions it'd be much appreciated. I'm stumped
Also curious about the heating on the pipes. They've been blue for a long time and they all seem to heat evenly.
Thank you
Matt
'81 KZ650. killing me slowly.
- Thank you received: 2749
- Trumpology101
www.kzrider.com/forum/2-engine/600223-valve-adjustment
That should hopefully get me through it and I'll try to find it in my manual. Got a project for this evening now, thanks!
- Thank you received: 1656
Compression check. make sure the battery is good & fully charged. remove all 4 spark plugs. Install the compression tester into the #1 spark plug hole. hold the throttle grip at WOT. press & hold the start button until the pressure stops rising. about 5 or 6 seconds. note the highest reading. also notice how the needle pulses. then do the other 3 cylinders the same way. write down the numbers immediately after checking each cylinder.
Kawasaki service manual. jarlef z650. the 1981 KZ650 pdf is in the Files section.
- Trumpology101
1 .005
2 .006
3 .006
4 .006
5 .008
6 .007
7 under .004
8 .010
Ive never done this before, does it seem correct?
I'm reading the manual as saying tolerances are between .08 and .018 so on the majority of them I'm not even there, does this call for replacing shims or is there any other way to adjust?
- Trumpology101
- Trumpology101
1. 130
2. 137
3. 122
4. 135
usable range of 137-209 with 14 psi difference between any two cylinders... so thats low.. i did have the camshaft cover off still though, was that a mistake? giving me inaccurate readings or shouldn't matter?
- Thank you received: 2829
1. Engine must be up to normal operating temperature.
2. Battery must be fully charged.
3. All spark plugs must be removed.
4. Throttle must be held fully open
5. Crank starter until highest compression reading is reached.
Checking compression without those requirements being met can give bogus readings.
If compression is found to be low check valve clearances to ensure vales are closing all the way.
If a compression problem is suspected run a leak-down test to isolate compression leak since it may not be related to piston rings. Do this BEFORE removing cylinder head.
- JR
- Thank you received: 448
If the figures above are in a HAYNES manual and are in mm then its probably a missprint. The Haynes manual for the 750 fours says valve clearance should be .08 to .018mm but it should read .08 to .18mm. I suspect yhe same missprint carried through to other manuals
On the other hand your readings for valve clearances look very much like inches. The equivalent spec in inches would be .003 to .007 i think but please double check.
Lots of oil in the cam area is a good thing
- Trumpology101
ah, engine was not up to normal operating temperature as I was checking valve clearance prior to the compression test.650ed wrote: Keep in mind, when checking compression.....
- Trumpology101
JR wrote:
Okay so converting it to mm gets me within spec on 1-6 but 7 is either barely in or under .08. my feeler gauge didnt go any smaller. 8 is around .254mm
Trumpology101 wrote: ...Ed ah, engine was not up to normal operating temperature as I was checking valve clearance prior to the compression test.
That could make a difference. When cold, the top of each piston is actually a little smaller in diameter than the bottom of each piston. The theory is that when the engine is at full operating temperature the piston tops are hotter than the piston bottoms and therefore expand a bit more than the bottoms. At that point that expansion should seat the piston rings properly in the cylinder bores. Below are a couple pics of stock KZ650 piston top and bottom measurements. Ed
