Kawa KZ's are the BEST....but - QUESTION
- JWKZ750
31 Jul 2017 18:28
Granted, Im new to vintage bikes and Im under 35 but i have a strong opinion.
I started biking last January (2016) and since accumulated 5 bikes. A 72 Honda CB350F, a 73 Honda CB 500F, a 72 Honda CB 750, a 77 Yamaha XS650 and a 77 Kawa KZ750B Twin.
Kawasaki bikes are the best of the lot. I have had or ever ridden a Suzuki, but Kawasakis are amazing.
Now, the question of the hour. my 77 had 10,000 original miles on it, and this thing seems to burn a bit of oil. Is that normal for a twin? NONE of my 4 cyl Hondas burn oil and we've checked the Kawa top to bottom. Compression, valves, timing, gaskets, all are in amazing condition. NO LEAKS ANYWHERE.
So, do your Kawa need topping up of oil every now and then?
Re: Kawa KZ's are the BEST....but - QUESTION
31 Jul 2017 19:22
Valve guide seals will cause that.
- JWKZ750
31 Jul 2017 21:35SWest wrote: Valve guide seals will cause that.
The other thing i neglected to do, which is pretty obvious, is put the bike on its center stand on LEVEL ground. I havent done that yet. WIl check tomorrow. Maybe the oil is fine...
01 Aug 2017 09:27
Oil level should be checked with the bike on the center stand while parked on level pavement. The oil level will rise when the oil is hot so know that as well if checking after a ride. It's better to check per the manual instructions: cool engine, start the engine and run for a min or so, then shut down and wait another min for the oil to settle.
The following user(s) said Thank You: BarnyardCoral
