Starter and crank bolt problems
  • Shdwdrgn
  • Shdwdrgn's Avatar Topic Author
Re: Starter and crank bolt problems
23 Jul 2017 19:50
#767567
Jumping back into this thread because I have a new problem. After sitting for most of the week I finally got the carbs adjusted and back on the bike, but when I hit the starter switch I got this grinding sound like gears. It will catch occasionally and I've managed to start the bike up a few more times over the weekend, but finally dug into it today to see if I could figure out the problem...
I ran across some other threads suggesting a similar sound would be heard if the starter clutch was not grabbing. Considering the previous problems, I thought this was a good place to start. When I popped the alternator back off again, I found what I thought was a loose bolt on the back of the clutch. Turns out it was actually a broken bolt. "Ah-HA!" I thought, surely this was my problem! Since the other unit I have has slightly shorter bolts, I swapped all three to maintain the balance, and used a piece of wood to smack the hex wrench and make sure the bolts were all snug. Confirmed there was no damage where the clutch grabs, then reassembled everything and tried again. UGH! Still making the same noises! I just don't see how it was working perfectly last weekend, then after sitting for a few days it suddenly is broken?
So then only other thing I can think of is the starter motor. Perhaps someone can tell me -- is the gear on the starter directly connected to the motor shaft, or is there internal gearing in the starter? If there is internal gearing, is it possible to take apart the starter? I have three starter motors sitting here, however only one of them actually works when power is applied. Another has a dead short in it, and the last is completely dead... BUT there is a good chance that I might be able to swap around internal components if something is broken in my working motor.
And in the off chance that there are NOT any internal gears in the starter motor... what else could it be? I had the timing cover off today and could see that the main crank was only hesitantly turning over, and there is no sign of grinding on the visible starter gears. Considering all the frustration with the engine idle speeds, it would be nice if I could at least get this part fixed.
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
  • Shdwdrgn
23 Jul 2017 21:23
#767571
I found some pics of a starter tear-down showing that the gear is actually ground into the motor shaft, so definitely no internal gearing like I was hoping.
I guess that means I'm back to the clutch again. Should I maybe hit the clutch ring surface (on the one-way gear) with some #600 emery cloth? I suppose there could be glazing similar to a disc brake that needs broken up and that surface does have a shiny polished finish to it. All three of the small steel cylinders are moving freely against their springs, and spinning the gear by hand caused them to lock and turn the engine.
1981 KZ1000-JK1
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
23 Jul 2017 21:33 - 23 Jul 2017 21:34
#767572
1. is it possible to take apart the starter? Yes you can.
2. is the gear on the starter directly connected to the motor shaft? Yes it is one piece shaft with no internal gearing.
It could be the bearings in the starter are damaged or the starter clutch did not disengage and and rev“s
the starter motor out of his limit. .
Have you check the starter clutch internal rollers and springs of any kind of wear?
Have you test that the starter gear turns freely counter clockwise?
Michael
Last edit: 23 Jul 2017 21:34 by Scirocco.
  • Shdwdrgn
24 Jul 2017 07:58
#767602
By the way, is the starter solenoid supposed to have some sort of built-in delay time to it? I've noticed when I touch the starter switch that the motor will continue to crank for a seemingly random period (up to a couple seconds) after I release the switch. Releasing the clutch and even turning off the key has no affect on this. At first I was thinking this was something meant to smooth out dirty contacts on the starter switch, but then it occurred to me that this was from 1981 and unlikely to contain anything like that.
1981 KZ1000-JK1
  • TexasKZ
  • TexasKZ's Avatar
24 Jul 2017 17:48
#767635
No delay. It should should stop right away.
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jul 2017 19:35
#767647
The damper may be too thick.
  • Shdwdrgn
24 Jul 2017 19:38
#767648
That's what I was thinking, the solenoid must be sticking then. Erg.
1981 KZ1000-JK1
  • Shdwdrgn
24 Jul 2017 20:24
#767651
@SWest -- This isn't the sound of the engine dragging the starter with it like I originally had. This happens when the engine isn't actually starting and I let go of the starter button. Since the button is dependent on both ignition power and the clutch kill switch (and it keeps trying to start even after I release the clutch and turn off the key), the solenoid is really the only thing that could continue applying power to the starter motor I believe.
As for the damper, it's still working as expected... once I torque the crank bolt I get a light drag in one direction and it locks in the other direction (at least by hand).
1981 KZ1000-JK1
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Jul 2017 20:41
#767655
If you can't find a stock one you can get one for a garden tractor.
  • Shdwdrgn
24 Jul 2017 21:00
#767659
I actually have one more, it's the right type but has different wires on it. Will need to break out the soldering iron to swap those smaller ones. Right now I'm more worried about trying to get it cranking over the engine reliably so I can get back to that idle problem again.
1981 KZ1000-JK1
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Jul 2017 21:12
#767660
1. It could be a weak or broken spring.
2. The iron piston could not move freely back cause by dirt or rust.
The following user(s) said Thank You: GPz550D1, BarnyardCoral
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Jul 2017 21:37 - 24 Jul 2017 21:40
#767661
For a quick and dirty test start.
Not the finest way to start but in case of an emergency.
Last edit: 24 Jul 2017 21:40 by Scirocco.
