bike bogs down
  • Frank2shots
  • Frank2shots's Avatar Topic Author
bike bogs down
08 Jul 2017 07:13
#766397
I own a 1982 kz550 LTD when I first start the bike up I can ride for like a half hour and then is the engine warms it starts to bog out on me not sure what the problem is any suggestions would help
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: bike bogs down
08 Jul 2017 07:19
#766399
Valve adjustments done?
The following user(s) said Thank You: Frank2shots
  • Frank2shots
Re: bike bogs down
08 Jul 2017 07:21
#766400
Nope not really sure how to do it as long as it's cool out it runs halfway decent never did it but I did get into I did get hit by a car
Re: bike bogs down
08 Jul 2017 08:24
#766404
Use the instructions in the Kawasaki Service Manual to check, and if necessary adjust, the bike's valve clearances. If you don't own the manual you really should buy one, but until then one that covers the 1982 KZ550-C3 (LTD) is available on KZRider at:
www.kzrider.com/modules/ServiceManuals/Kz400500550_79to83.pdf
Re: bike bogs down
08 Jul 2017 08:28 - 08 Jul 2017 08:30
#766405
Frank2shots wrote: I own a 1982 kz550 LTD when I first start the bike up I can ride for like a half hour and then is the engine warms it starts to bog out on me not sure what the problem is any suggestions would help
Possible obstruction in the fuel tank cap vent resulting in fuel starvation.
Test by riding with the fuel tank cap ajar (not snapped down), which assures ample venting through the partially open cap.
And of course assure fuel level is adequate before the test run.
Might also be crud suspended in the fuel that's accumulating around and obstructing the petcock pickup screens. If so, would remove, disassemble and clean the petcock and screens; and remove and flush the fuel tank using the fast dump method through the filler opening, add some fresh fuel or common household rubbing alcohol and re-dump. Repeat flushing until tank interior is free of any loose sediment or other type crud.
Good Fortune! :)
Last edit: 08 Jul 2017 08:30 by Patton.
The following user(s) said Thank You: GPz550D1, Frank2shots
  • Frank2shots
Re: bike bogs down
06 Aug 2017 06:23 - 06 Aug 2017 06:23
#768433
I have a tear in one of my wire boots then I put electrical tape around could that also be the issue of it bogging
Last edit: 06 Aug 2017 06:23 by Frank2shots.
  • TexasKZ
  • TexasKZ's Avatar
Re: bike bogs down
06 Aug 2017 06:52
#768434
Tears and cracks in the ignition wiring can cause misfires, but are not time or temperature sensitive as you have described.
Valve clearances and fuel delivery are the most common culprits.
Performing ALL the routine maintenance as described in the factory service manual is the best way to eliminate and prevent a host of problems.
