Shift rod
- Fox
Shift rod
12 Jun 2017 16:48 - 12 Jun 2017 16:50
Hello,
when i ride, the cerclip of the shift rod (where the 2 small shift forks are placed in the tranny) jump.
I replace it yesterday by a new one, and make a turn, but jump again.
I think it's the shift rod who is tired.
I'm going to replace it tonight and place on it red treadlocker (permatex)
Do you think it will be enought to fix it in place?
The other idea i have is to rebuild the shift rod line .... perhaps with a dremel...
(where the cerclip is)
Any idea, or refexion will be welcome
All the best
All the best
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Last edit: 12 Jun 2017 16:50 by Fox.
Re: Shift rod
12 Jun 2017 17:37
:Pic?
- Fox
Re: Shift rod
12 Jun 2017 19:13
Hello,
This is the same shift rod i have in place
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Re: Shift rod
12 Jun 2017 19:45
It shouldn't move with the cover in place unless something is wrong with it.
The following user(s) said Thank You: Fox
Re: Shift rod
13 Jun 2017 06:50
I hope you know what you're doing. If you pull the shift rod out too far or all the way, the shift forks will fall down into the oil pan. The 650 manual says not to pull it out more than 40mm.
- Fox
Re: Shift rod
17 Jun 2017 12:28 - 17 Jun 2017 12:31
Hello,
yes i know. The problem is i can't remove the shift rod. It don't come from the tranny side.
I really try, but impossible. It just come 2 or 3 mm after the cerclip and then stop.
(I would like to remove it and replace it by a new one that i have.
Then it will be possible to check the 2small forks too by the oil pan...)
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Last edit: 17 Jun 2017 12:31 by Fox.
Re: Shift rod
17 Jun 2017 15:49
I really don't know much about it, but I think if you pull the shift rod out, you have to split the crankcase to reinstall the shift forks. probably not something you want to do. not unless it's necessary of course.
