Cylinder head reboring or change jug
- Sharky
03 Jun 2017 09:01 - 03 Jun 2017 10:27
Good evening,
My cylinder walls have 4 deep groves, as a result of oil ring that broke.
I have 2 options:
1. re bore to 0.5 or 1mm depending on the depth of the groove
2. Buy a second hand cylinder jug.
The problem with the 1st is that I cannot find pistons to that size and rings....
Do you think that old pistons with new rings will go ok in an SH jug?
My bike is a 1978 KZ400 B1
This is the jug :http://www.ebay.co.uk/itm/1978-Kawasaki-KZ400B-78-KZ-400-B-Cylinder-Jug-/232095318168?hash=item3609f58098:g:MRkAAOSwmfhX6R66
I have 2 options:
Last edit: 03 Jun 2017 10:27 by Sharky.
Re: Cylinder head reboring or change jug
03 Jun 2017 09:40
Pics?
- Sharky
07 Jun 2017 12:18
can i change piston part number 13029-1006 with the older model 13029-070 .
I don't have any other option as cannot find the 1st one to buy...
07 Jun 2017 13:11
Your bore / stoke is 64,00 mm x 62,00 mm on all KZ400 models excepted the KZ440 with 67,50 mm x 62,00 mm
Source: kz400.com/TechnicaldataFrameset.html
found two sides where you can buy over size piston and rings
www.cmsnl.com/kawasaki-kz400b1-1978-cana...t/51457.html#results
www.scheuerlein-motorentechnik.de/motorr.../Z400-Modelle/Z400D/
The following user(s) said Thank You: GPz550D1, Sharky, vinSanity
- Sharky
07 Jun 2017 14:46
Thank you very much Scirocco but on the first site they dont have them. And on the German one they do but they are for the 75-78 model not mine. As I stated before. I dont think I have a choice and ill buy the old version ones's , as I cannot find the proper ones anywhere. part no. 13029-1006.
Thanks for the help
Thanks for the help
- kozajr
25 Mar 2018 03:28
Hello Sharky, how did it end up?
I'm in middle of motor repair of my kz400 1979 and im looking for 1mm oversize pistons and oil rings. But i cant find it anywhere. However i found set of +1mm piston and oil ring for 1976-78 kz400, part number 13027-066. Pistons have sligthly different design, but bore and stroke was on all kz400 same, so it might work? What do you think guys?
Please see the pics. Piston with round head is original for my model and piston with flat head is for older models..
- Nebr_Rex
25 Mar 2018 16:16
Yes, those pistons will work.
Another alternative is to take it out to 67.5mm and make it a 440.
The sleeves will go that far.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nebr_Rex
25 Mar 2018 16:23
The head and the cam are the same between the late 400 and the 440.
About the only things that are a hold over from the early engine is the
kick start cam chain.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
