1973 Z1 900 Cylinder Condition
- gvsu141
17 May 2017 13:29
I posted on my project page, but wanting to post here for more visibility.
I have the head off doing valves on my 1973 Z1, and have questions on the condition of the cylinders. Pics below. Should I bolt it back up as is? New rings with a hone? go .5mm oversize? Something else? Currently bore measures the stock 66mm. Funds are limited due to the rest of the $$ I've already put into this project.
Compression was 125+ on cylinders 1, 3, & 4. Was down to about 105 on cylinder #2. I didn't do a leak down test before I pulled the head.
Valve seats were clean, just a decent amount of carbon in the domes. Seats clean makes me think they're seating OK. Intake guides were pretty loose, and a couple seals leaky on 1 & 2.
Cylinder #2 looks OK at a glance (once again more carbon), No major scoring or gouges from what I can tell. If I shine a flashlight on it, I can see some vertical marks, but doesn't seem too bad, though I'm no expert. Nothing that I could even catch a finger nail on, felt completely smooth. (Last Picture) I can feel a slight lip at the very top of all of the cylinders.
[/quote]
[/quote]
2001 ZRX 1200
1973 z1 900
1975/73 z1 Turbo Dragbike
1982 GPZ550 - 62 Miles
1973 z1 900
- gvsu141
Re: 1973 Z1 900 Cylinder Condition
17 May 2017 13:31
Just to note, the bike seemed to run pretty well beforehand.
2001 ZRX 1200
1973 z1 900
1973 z1 900
17 May 2017 14:29
Do you have access to a bore gauge? If the out of round and taper is .001" or less than a bottle brush hone could be used to prep the cylinder for new rings.
- gvsu141
17 May 2017 14:53Nessism wrote: Do you have access to a bore gauge? If the out of round and taper is .001" or less than a bottle brush hone could be used to prep the cylinder for new rings.
I don't, but looks like harbor freight has a cheap set that might work good enough.
2001 ZRX 1200
1973 z1 900
1973 z1 900
17 May 2017 15:37
Pics of the pistons?
- gvsu141
18 May 2017 07:29SWest wrote: Pics of the pistons?
Anything specific you want to see? Right now the cylinder is still on the bike.
2001 ZRX 1200
1973 z1 900
1973 z1 900
18 May 2017 07:53
Wear etc. Be sure to get all the carbon. It will scratch the walls.
- Kidkawie
- I bleed premix
18 May 2017 08:17 - 18 May 2017 08:21gvsu141 wrote:Nessism wrote: Do you have access to a bore gauge? If the out of round and taper is .001" or less than a bottle brush hone could be used to prep the cylinder for new rings.
If you use an actual bore gauge with dial you need a micrometer to set it up. You can get by with a set of calipers but micrometer is the way to go. They also have T bore gauges but I prefer the gauge.
Set the micrometer to the bore diameter, install specified adapter to bore range on gauge, set the dial bore gauge within the micrometer and set the dial to zero, insert the gauge into cylinder and read the runout. Bottom, middle and top 12-6:00 and 3-9:00. If the runout falls within spec, you're good.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 18 May 2017 08:21 by Kidkawie.
- gvsu141
19 May 2017 09:17 - 19 May 2017 09:18
I rechecked my notes from a while ago when I did the compression test. Turns out my actual readings were 130/105/118/119. However, this was with several tight valves, so hard to tell much from that alone.
2001 ZRX 1200
1973 z1 900
1973 z1 900
Last edit: 19 May 2017 09:18 by gvsu141.
- gvsu141
19 May 2017 09:33 - 19 May 2017 09:34
I'm may just end up going a size or two over anyways since it's apart. Would be pretty much a brand new engine.
It's tempting to go with a set of Weisco 1015 10.5, but I should just probably keep it stock. I have my ZRX to hot rod in.
2001 ZRX 1200
1973 z1 900
1973 z1 900
Last edit: 19 May 2017 09:34 by gvsu141.
- VTEC
20 May 2017 10:20 - 20 May 2017 10:21
See how the top of the pistons are clean around the edges, carbon mostly in the middle? An engineer once told me they call that the "halo effect" from excessive oil getting by the rings.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
Last edit: 20 May 2017 10:21 by VTEC.
22 May 2017 08:13
if the bore is good a hone and new rings with the proper gap should be all that's needed.
save the bores!!!!they are only that size once!
