1973 Z1 900 Cylinder Condition
Re: 1973 Z1 900 Cylinder Condition
22 May 2017 08:20 - 22 May 2017 08:22531blackbanshee wrote: if the bore is good a hone and new rings with the proper gap should be all that's needed.
save the bores!!!! they are only that size once!
Exactly! Ed
Last edit: 22 May 2017 08:22 by 650ed.
- gvsu141
02 Jun 2017 10:28 - 02 Jun 2017 10:29
I found a set of the telescoping bore gauges in the garage that I didn't even know I had! Similar to the ones here:
www.amazon.com/gp/product/B000I8NDAS/ref...3d0&pf_rd_i=15708741
I'm going to get some more precise measurements tonight, but cylinder #2 (the one with lowest compression) measured around 2.617-2.618 inches on a quick check - which converts to 66.47-66.49 mm. The other cylinders were closer to spec, around 2.599" - 2.608"
So it looks like i'll need to go at least one size over. If measurement for #2 is accurate, is this still acceptable to go the first size over? Or would I need to go to the 2nd size over?
I really would love to save the bores, but it looks like they may just be too worn out.
2001 ZRX 1200
1973 z1 900
1975/73 z1 Turbo Dragbike
1982 GPZ550 - 62 Miles
1973 z1 900
Last edit: 02 Jun 2017 10:29 by gvsu141.
02 Jun 2017 14:44 - 02 Jun 2017 14:46
I don't trust those telescoping gauges. Way too hard to get a good measurement.
A getto check can be performed by sticking a ringless piston down into a bore and try cutting a feeler gauge between the skirt and cylinder at various places. The wear is typically at it's max about an inch down from the deck surface (or there abouts). If you can get a .004" feeler between the skirt and wall perpendicular to the pin then you got yourself some excess wear.
Last edit: 02 Jun 2017 14:46 by Nessism.
The following user(s) said Thank You: dkoz
