Valve adjustment Z1/KZ 1000
Re: Valve adjustment Z1/KZ 1000
04 Sep 2019 20:13
Found some tight ones.
The following user(s) said Thank You: kzed
05 Sep 2019 16:28
It was worth it.
- Mitch`s KZ
01 Aug 2020 14:30
hey there my freind, I am totally new to both kz 1000 and the forum.The last time I had one was 1982. Stumbled across accidentally. Anyway I Just recently purchased another one. 1977 KZ 1000a. I bought it from Johnnys vintage cycles in Ohio. I am checking out your video on replacing the electrical wiring, and I noticed you have some kind of radiator on the front of your bike. Man things have come along way since my bike in the 80s. Can you tell me what its for and the benefits it has. Your bike is well kept. Mine was blue in the 80s. The one I purchased is Black with gold pin stripping. I don`t care what collar they are, they still look better than anything else out there. Thanks Mitch
Mitch
- zed1015
01 Aug 2020 14:49The "Radiator" is an oil cooler.Mitch`s KZ wrote: hey there my freind, I am totally new to both kz 1000 and the forum.The last time I had one was 1982. Stumbled across accidentally. Anyway I Just recently purchased another one. 1977 KZ 1000a. I bought it from Johnnys vintage cycles in Ohio. I am checking out your video on replacing the electrical wiring, and I noticed you have some kind of radiator on the front of your bike. Man things have come along way since my bike in the 80s. Can you tell me what its for and the benefits it has. Your bike is well kept. Mine was blue in the 80s. The one I purchased is Black with gold pin stripping. I don`t care what collar they are, they still look better than anything else out there. Thanks Mitch
Mostly for hard use , racing or in hot climates to help keep oil temperature and consequentially engine temperature down.
- mikebmeehan
26 Nov 2020 01:51
Great post and thank you for sharing. I'll be watching these videos.
- Robb2018
- 76 KZ900 73 Z1 A
- Robb2018
- 76 KZ900 73 Z1 A
10 May 2021 06:02 - 10 May 2021 06:04
Curious... do you check valve clearances on a set schedule or wait till they start making noise? And will they in fact make noise when they start getting tight?
KZ900; Z1
Last edit: 10 May 2021 06:04 by Robb2018.
- zed1015
10 May 2021 06:14The tighter they get the quieter they go.Curious... do you check valve clearances on a set schedule or wait till they start making noise? And will they in fact make noise when they start getting tight?
You should really check them once a year if in regular use.
The following user(s) said Thank You: Robb2018
10 May 2021 07:56
I do it with each rear tire change. About 5,000 miles.
12 May 2021 08:14
- Riley445
10 Jan 2022 19:53
Thanks For Share your video with Us. It's Very Informative Helps me a lot
10 Jan 2022 19:59
Riley
Your next post should be a post in new members with a introduction
The following user(s) said Thank You: Riley445
