KZ1100 A2 - My oil filter cover broke
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: KZ1100 A2 - My oil filter cover broke
11 May 2017 21:28
#761793
Good luck.
The following user(s) said Thank You: vonhaas
  • vonhaas
  • vonhaas's Avatar Topic Author
11 May 2017 21:52
#761795
SWest wrote: Good luck.
Thanks, I think I need it B)
1982 KZ1100A2
1981 KZ1100A1
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 May 2017 05:58
#761810
If you put a wire through the oil galley from the inspection port, you should be able to see it at the inlet port for the riser. If that's clear you should be good to go.
  • vonhaas
12 May 2017 10:36
#761828
SWest wrote: If you put a wire through the oil galley from the inspection port, you should be able to see it at the inlet port for the riser. If that's clear you should be good to go.
Good advice! I'll do just that!
1982 KZ1100A2
1981 KZ1100A1
  • vonhaas
15 May 2017 16:49
#761995
Quick update. The 4th oil filter cover came today. I checked the inspection port for clogs and the like and it was clear. Took the plug out of the oil pressure sensor housing, installed a new oil filter and cap, filled her with oil and started her up. SUCCESS!!! My parts bike runs great with a few blips. Seems I'm burning oil in either the 1 or 2 cylinder (white smoke) and my tach just stays on 3000 rpms. Need to troubleshoot those, but I now know she's has a running motor :woohoo:
1982 KZ1100A2
1981 KZ1100A1
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 May 2017 19:14
#762000
Good job. So the pug was in there the whole time?
  • vonhaas
15 May 2017 23:00
#762009
SWest wrote: Good job. So the pug was in there the whole time?
Yeah, when I grabbed the oil sensor housing from the parts bike, the plug was in there, hence the oil pressure build up. As for the tachometer, it turned out the old one was broken but my parts bike had a working one. ;) The whitish smoke coming from the #1/2 exhaust after it was warmed up seems to have gone away after I found the photos I had of the coil wires. Apparently they were all reversed. :dry:
1982 KZ1100A2
1981 KZ1100A1
