2000 KZ1000 Replaced Clutch/no lever pressure
- STotten
02 May 2017 14:03
Hi, I just picked up a 2000 KZ1000 former police bike. Only thing that was wrong with it is that the Clutch plates needed to be replaced. I replaced them, and as I was going to the next step of the instructions, I was a dummy and I squeezed the clutch lever while the adjustment screw cover (Left side of the engine) was off. Now there is no clutch pressure.
Can anyone explain what I did and how to fix it?
Re: 2000 KZ1000 Replaced Clutch/no lever pressure
02 May 2017 14:37
Clean, grease and install the ball and ramp actuator. Adjust the screw after installing the sprocket cover then adjust the cable.
- STotten
02 May 2017 14:43
Hi Steve, Thank you! The ball and ramp actuator, I am not familiar with these (Probably have seen them, just didn't know their names) where will I find these?
02 May 2017 15:50
AKA EZ PULL> They're known for that. Inside the sprocket cover where the cable attaches.
- STotten
02 May 2017 16:25
Thank you so much! it might be a few days before I get to it, but I will let you know if it works.
Thank you!
Thank you!
- Gordoninnc
03 May 2017 05:16 - 03 May 2017 05:18
STotten, I just went through this about three weeks ago. I'm new to the site and I'm not sure how to post a link to the thread but you can search for it.
Forum - Technical Forums- Engine - 2002 KZ1000 Police Clutch problem
Search for 2002 KZ1000 Police Clutch problen, author Gordoninnc.
You will see some photos of the "ball and ramp" set up and it should help to shed some light on the subject.
I'm going to ask.....but you said you replaced the clutch plates. Both the friction and the plain??? You probably knew but the friction are directional and it's thought that the cut edge of the plain plates should face the pressure plate. Just saying.
Take care and good luck, seems to be several KZP owners here on this site.
Gordon in NC
Gordon in NC
Last edit: 03 May 2017 05:18 by Gordoninnc.
03 May 2017 06:54 - 04 May 2017 04:11
When installing the cable, there should be a spring & cotter pin at the clutch release mechanism to keep the cable end seated.
A 1/16 x 1" cotter pin is a close match. I hate rust, so I install a ss cotter pin.
Last edit: 04 May 2017 04:11 by martin_csr.
03 May 2017 07:10
Remove sprocket cover
Remove ball and ramp device (the small part the clutch cable attaches too)
Clean old grease and apply fresh
Install ramp device such that the angle of the arm is roughly 90* to the cable path. Most likely when you pulled the lever the ramp jumped over the top, moving it too far CCW.
Install sprocket cover
Adjust ramp device using screw on cover, then snug down the lock nut.
- STotten
03 May 2017 07:37
Hi Gordon, thank you for the tip. I didn't actually know that the friction plates are directional. I will uninstall and reinstall. How do you know which direction they are supposed to face?
Thanks!
Thanks!
03 May 2017 07:53
Here's a cut and paste from the KZ1000 / KZ1100 Kawasaki Service Manual (not Police bike specific, but probably the same advice). Ed
- Gordoninnc
03 May 2017 10:23
Crap.......getting old isn't for sissies so I'll need to get back home and check my notes. But I "think" our KZ1000 Police's clutch runs counterclockwise. So when your looking at the friction plates as installed in the basket the grooves in the palate will make a / forward slash???
I swear I just just got through doing this but I'm not 100% sure of that but will check again tonight.
Plain steel plates......have a rounded edge and a sharp edge.....easy to feel. Install the sharp edge toward the pressure plate.
I'll report back after I review my notes.........I suffer from CRS.
Gordon in NC
Gordon in NC
- Gordoninnc
03 May 2017 19:13 - 04 May 2017 03:38
Okay, that was right, clutch turns counterclockwise so the grooves in the OEM friction plates make a / (forward slash) as viewed looking into the clutch basket. It's supposed to help the plates shed oil.
Good luck...Gordon in NC
Check out this thread for photos of the ball and ramp mechanism ....KZ1000 Police
www.kzrider.com/forum/2-engine/605632-20...problem?limitstart=0
Last edit: 04 May 2017 03:38 by Gordoninnc.
The following user(s) said Thank You: STotten
